  3. swap instances given instance name.
  • Subscribers 152
  • Views 18460
marbs
marbs over 16 years ago
Hi all,
I would like to ask, how to swap instances in layout,
given the instance's name.  For example,  I would like to
swap the instances |M34  to |M335, how to do that in SKILL ?
Thanks in advance,
Marbs
  • Quek
    Quek over 16 years ago
    Hi Marbs
    A simple way to do it would be as follows:
    CCSswapInst("|M34" "|M335")
     procedure( CCSswapInst(inst1 inst2)
       let( (cv id1 id2 temp)
          cv=geGetWindowCellView()
          id1=dbFindAnyInstByName(cv inst1)
          id2=dbFindAnyInstByName(cv inst2)
          if( id1 && id2 then
             temp=id1~>xy
             id1~>xy=id2~>xy
             id2~>xy=temp
             printf("%s and %s have been swapped\n" inst1 inst2)
          else
             printf("Instances not found\n")
          ) ;if
       ) ;let
    ) ;procedure
    Best regards
    Quek
    swapinst.il
  • marbs
    Thank you for the code sir,
    but how can I run this code in CIW ?
  • Quek
    Hi Marbs
    Please load it in ciw using:
    load "swapinst.il"
    After loading it, enter the following in ciw:
    CCSswapInst("|M123" "|M456")
    By the way, when posting a question, it would be great if you can state the specific version of software which you are using so that we can come up with the best solution for you. : )  Tool versions can be obtained using commands such as:
    unix>icfb -W
    unix>icms -W
    unix>virtuoso -W
    unix>assura -W
    unix>spectre -W
    unix>ultrasim -W
    unix>vcar -W
    unix>qrc -version
    unix>ncsim -version
    unix>encounter -version
    unix>eps -version
    Best regards
    Quek
    Also, in Layout XL there is Edit->Other->Swap Components. In IC613 it is Edit->Advanced->Swap Components (again, in VLS XL).
    So it's a built-in capability if you want to do it interactively.
  • marbs
    Thank you very much sir,
    I am now able to run the skill code you have given.
    Sorry for my late reply because I am very busy for the last week.  I will follow your instruction about posting a question next time.
    Marbs
