  3. Virtuoso XL Probe Command
  • Subscribers 152
  • Views 15960
RoiZano
RoiZano over 16 years ago
I want to use the prob prop and i dont want to open the prob form.
Please I need the Probe command  only...
Roi.
  • Quek
    Quek over 16 years ago
    Hi Roi
    Hope that this will solve your problem:
    a. Save the script as "probe.il" in the working directory where you started icfb
    b. Enter the following in ciw:
    load "probe.il"
    c. In VXL mode, press F10
    procedure( CCSprobe()
       hiRegTimer("hiiToggleEnterForm(lxProbeForm)" 1)
       lxHiProbe()
    ) ;procedure
    hiSetBindKey("Layout" "F10" "CCSprobe()")
    Best regards
    Quek
    probe.il
  • RoiZano
    Thank You !!!
    It worked !!!
    Roi.
