  3. How to change the UNITS while generatin DEF
  • Subscribers 152
  • Views 16123
latha
latha over 16 years ago
I am exporting def for my block.
In the def,  UNITS DISTANCE MICRONS 100, bur i need 1000 instead of 100.
where i can set this option.
latha
  • Quek
    Quek over 16 years ago
    Hi latha
    Please refer to COS solution 11010243. You need to add a property named "gec3DBUPerUU" to your technology library.
    a. In the library manager, right click on your technology library (e.g. the name might be tsmc018, chrt013, etc)
    b. Select "Properties" and then click "Add" button to add a new property
    c. Set "type" to "Float" and "value" to "1000"
    Best regards
    Quek
  • latha
     Thanks, Now it is working..
