  3. For loop
  • Subscribers 152
  • Views 29144
For loop
sprinter
sprinter over 16 years ago
 The 'for' loop increments in steps of 1. Is there a way to increment or decrement with a non-unity step?
If I've a list of values to evaluate an expression(s) then 'foreach' is used but I couldn't find something for a range of values & with an arbritrary step size. Any comments?
Adil.
  • mir0mik
    mir0mik over 5 years ago +1
    I know this is a pretty old topic, but I was looking for exactly this and I think of this solution... for( cnt -10 0 println( abs( cnt)) ) 10 9 8 7 6 5 4 3 2 1 0
    You could use the SKILL++ do() function, or simply use a while loop:
    i=0
    while(i<20
      println(i)
      i=i+2
    Or look at solution 11025352 on support.cadence.com - this is one I wrote on "Understanding SKILL macros". There's a macro on implementing a C-like for loop.
  • sprinter
    Thanks a lot.
    The note on the macro is quite useful for new users like me.
    On a different subject, I'm wondering what's the best way to debug a SKILL code? I mean is there a tool which could be used for the editor. Right now I"m relying on the error messages I see in my CIW.
    Adil.
    Adil,
    If using IC613/IC614 you have Tools->SKILL Development Environment (New) which is a GUI based tool which allows you to place breakpoints on lines in the code, trap errors, trace variables and so on.
    You also have the older Tools->SKILL Development menu which brings up the toolbox which gives access to a debugger - again, it can intercept errors and put breakpoints at the beginning or end of functions.This is also in older releases.
    For more info look in  <instdir>/doc/skhelp/skhelp.pdf and <instdir>/doc/skdevref/skdevref.pdf
    Note that this is a licensed tool - it requires product 900 (SKILL Development Environment).
  • sprinter
    Thanks once again for the info on the development tool - sounds very useful indeed. I checked the list of products we've currently & unfortunately this is not available.
    Best regards,
    Adil.
    Andrew Beckett said:
    Adil,
  • mir0mik
    for( cnt -10 0
    println( abs( cnt))
    10
    9
    8
    7
    6
    5
    4
    3
    2
    1
    0
