  3. help: (* inherited_mfactor *) <<--? syntax error
  • Views 1413
feiyu
feiyu over 16 years ago
Hi, all
I simulate a schematic with verilog-a modules use cadence spectre.
netlist is ok but error is found by simulation
Command line:
/home0/cadence./tools.lnx86/spectre/bin/32bit/spectre -env \
artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre8_3347_3 -format sst2 -raw ../psf +lqtimeout \
900 input.scs
spectre pid = 4252
Loading .../libinfineon_sh.so ...
Loading ...
spectre (ver .5.10.41_USR3.102405 --24 Oct 2005).
Includes RSA BSAFE (R) Cryptographic or Security Protocal Software from RSA
Security, Inc.
Simulating 'input.scs' on ass1 at time.....
Error found by spectre during AHDL read-in.
"/home0/...../module.va", line 20: "(* inherited_mfactor *)<<--? parameter real m=1;"
"/home0/...../module.va", line 20: Error: syntax error
spectre terminated prematurely due to fatal error.
Line 20 in module.va is:
(* inherited_mfactor *) parameter real m=1;
Do anyone knew what happened? and how to slove this question?
    You're using a really old version of spectre. Whilst spectre is still in the IC5141 stream, since late 2004 there has been a separate stream for the analog simulators, called "MMSIM" which should be used instead of the spectre that's in IC5141 (in newer IC releases, spectre is not included).
    If I use any version of MMSIM (MMSIM60, MMSIM61, MMSIM62, MMSIM70, MMSIM71, MMSIM72 - as you can see, there have been quite a few releases - one major release per year), the (* inherited_mfactor *) syntax is supported.
    In IC5141 you could do a similar thing, but it used an older syntax:
     parameter real (* integer inherited_mfactor; *) m = 1;
    rather than
    which is the newer syntax.
    So I would suggest you use a supported version of spectre (e.g. MMSIM71 or MMSIM72), but if you really can't, you should be able to change the model to use the old syntax.
  • feiyu
    rather than
    Thank you very much.
    I have soloved this problem, changed the model accroding your suggestion.
    Best Regards!
