  3. Enable ALT Key on OA
  • Views 16794
RoiZano
RoiZano over 16 years ago
I need to enable the ALT key on OA (Virtuoso 6.1).
Could some one help me with that .
Roi.
  • dmay
    dmay over 16 years ago
    Add the following to your .cdsenv file:
    ui      enableMenuShortcuts     boolean nil
    The Alt key is used with some menu shortcuts in IC 6.1. You must disable this before Cadence starts (by putting it in your .cdsenv).
    Derek
  • RoiZanoNew
    RoiZanoNew over 16 years ago
    Working !!!!
    Thank You!!!
  • saranghe09
    saranghe09 over 16 years ago
     yeah right, have this problem too and lucky to be able to solutions here...:)
