  3. Select pins and pin label by SKILL.
  • Replies 9
  • Subscribers 153
  • Views 23786
marbs
marbs over 16 years ago
Hello All,
How can I select all pins and pin label in the layout
having no connectivity  by using SKILL  ?.   Because i find it
difficult to select all the pins in my layout that have no connectivity,
if I select it oned by one.
Any help are appreciated.
Thanks in advance,
 Marbs
  • Quek
    Quek over 16 years ago
     Hi Marbs
    A layout pin must have a terminal and net name. So it will definitely have connectivity info in its properties form. Just to clarify the question, do you mean that you would like to select isolated layout pins that are not touching any other devices/interconnect?
    Best regards
    Quek
  • marbs
    Yes sir, thats what I mean,
    I want to select all isolated pins in the layout that are not touching any other devices,
    by using skill.
    Please help.
    Marbs
  • Quek
    Hi Marbs
    You can find the pins using the skillscript below. Save it as "findpins.il" in your working directory and load it in ciw using:
    load "findpins.il"
    Press F10 in a layout and note the output messages in ciw.
    In general, you can start coding such a script using the following steps:
    a. Identify the target. In this case, it is a pin
    b. Identify unique properties on the target through ~> operator:
    - Select the target in layout/schematic
    - Enter a=car(geGetSelSet()) in ciw to get a handle to the target
    - Use a~>? to know more about the target
    c. After you have some idea on its properties, do some looping to get it
    d. Make some guesses on the type of skill functions needed. E.g. we need to select the pins so we will need some selection functions
    e. Refer to the appropriate manuals for the skill functions. E.g. for layout, look in sklayoutref.pdf
    f. $CDSHOME/doc/skdfref/skdfref.pdf and $CDSHOME/doc/sklayoutref/sklayoutref.pdf are very useful manuals
    Best regards
    Quek
    procedure( CCSfindPins()
       let( (cv allPins count overlapShapes)
          cv=geGetWindowCellView()
          allPins=setof(x cv~>shapes x~>pin)
          count=0
          foreach( pin allPins
             overlapShapes=dbGetOverlaps(cv pin~>bBox pin~>lpp 0:32)
             unless( length(overlapShapes)>1
                geSelectFig(pin)
                count++
                printf("Isolated %L pin with net %s found at %L\n"
                     pin~>lpp pin~>net~>name centerBox(pin~>bBox))
             ) ;unless
          ) ;foreach
          printf("%n isolated pin(s) selected in cell %s\n"
                                                   count cv~>cellName)
       ) ;let
    ) ;procedure
    hiSetBindKey("Layout" "F10" "CCSfindPins()")
    findpins.il
  • marbs
    Hi Sir,
    Thank you very much for the skill code and the clear
    skill coding instruction.
    Marbs
  • ashkumar
    ashkumar over 16 years ago
    hi,
    i have a script which modify a cell and save it as a different name in same library.
    But its unable to change the label  (text).
    Please help me with this.
    Thanks & regards
    ashutosh
    ashutosh,
    Try reading your post, with the assumption that the reader has no knowledge (other than what you typed) of what your problem is. In other words, they do not have access to the knowledge of the problem that resides in your head.
    Do you think they'd be able to answer it?
    Also, it probably would have made more sense for this to be a new topic, unless it is very closely related to the original question (it's unclear since you gave no details whatsoever).
    Ask a vague question, and you'll either get a vague answer (or more likely no answer at all).
  • ashkumar
    Thanks for the reply.
    I will try to elaborate it. I am working on some standard cell library. Some cells has to be modified and saved with different cell name in same library. My skill script is copying the cell and after modification its saving it with different name as required.
    for eg initial cell : muxprx1   new cell: muxprstx1
    But in the modified cell(muxprstx1)  label is same as muxprx1.
    so can you suggest me how to modify the label text using skill.
    Regards
    ashutosh
    Assuming you have two variables, oldCellName and newCellName and a variable cv containing the cellView id, then something like the following would do it:
    ; in case you haven't already got the cellView open
    ; cv=dbOpenCellViewByType(libName newCellName viewName "" "a")
    foreach(shape cv~>shapes
      when(shape~>objType=="label" && shape~>theLabel==oldCellName
        shape~>theLabel=newCellName
    dbSave(cv)
    Again, bit of a wild guess because I don't know what form the label you've got actually is.
  • ashkumar
    Thanks a lot.
    It wll be of great help.
    Regards
    ashutosh
