  3. How to add prefix to all instances
  • Subscribers 150
  • Views 23145
maven7783
maven7783 over 16 years ago
Hi All,I need a SKILL code for adding prefix or suffix to a top-cell and to all its instances.For eg: I have a Top cell ( INV)  and it has subcells called as a instances. INV hierarchy :  INV-> INV_PMOS-> INV_NMOS So, I want to add some prefix/suffix for all the cells in the hierarchy. Ex: myprefix_INV->myprefix_INV_PMOS-> myprefix_INV_NMOS Thanks,Maven.
  • Quek
    Quek over 16 years ago
     Hi maven
    The following COS solutions work on cells listed in the library manager. It is not exactly what you have requested but I think it can also solve your problem. You can first do a hierarchical copy of your top cell to a new library before applying the skillscript.
    11026492 : How can I rename all cells in a library with a specific prefix?
    11166194 : Add prefix/suffix to only some cells
    Hope that this helps you. : )
    Best regards
    Quek
  • maven7783
    Thanks Quek,
    Your link gave me an idea to approach the problem.
    But the solution in the COS used ddGetObj() function which cannot traverse to the instances of a cell.
    So i used dbOpenCellVeiwByType() to get instances but its not effective could not complete the program.
    Could you suggest me a function which can traverse through libname~>cellname~>instances for a given libname and cellname.
     (dont tell me geEditCellView())
    If i can get that then my script is done.
    Maven.
  • Quek
    Hi Maven
    You can use the following skillscript. It will find all subcells in a top cell and write the cellnames to a file. You can then use solution 11166194 to do the renaming. : )  Save the script as "findcells.il" in your working directory and execute it as follows:
    load "findcells.il"
    CCSwriteCells("myLib" "myTopCell" "myView")
    where "myView" can be either schematic or layout. The cell names will be written to a file named "list_cell".
    procedure( CCSfindAllCells(myLib myTopCell myView)
       prog( (allSubCells topCv allInsts cellList)
          allSubCells=list()
          topCv=dbOpenCellViewByType(myLib myTopCell myView)
          allInsts=topCv~>instances
          foreach( inst allInsts
             unless( member(inst~>cellName allSubCells)
                allSubCells=append1(allSubCells inst~>cellName)
                cellList=CCSfindAllCells(inst~>libName
                    inst~>cellName inst~>viewName)
                if( listp(cellList) then
                   allSubCells=append(allSubCells cellList)
                ) ;if
             ) ;unless
          ) ;foreach
          return(allSubCells)
       ) ;prog
    ) ;procedure
    procedure( CCSwriteCells(myLib myTopCell myView)
       let( (outPort cellList)
          outPort=outfile("list_cell")
          cellList=CCSfindAllCells(myLib myTopCell myView)
          foreach(cell cellList
             fprintf(outPort "%s\n" cell)
          ) ;foreach
          close(outPort)
          outPort=nil
          printf("List of subcells have been written to file list_cell\n")
       ) ;let
    ) ;procedure
    Best regards
    Quek
    findcells.il
  • Kbrota
    Kbrota over 7 years ago in reply to Quek
    Hi Quek, the link you shared here is not working here anymore. Is it possible for you to paste the code here? I know it is 9 years old post, but, your solution seems more relevant to the problem I have right now.
    Andrew Beckett over 7 years ago in reply to Kbrota
    I fixed the links for Quek - so they are now working.
  • Kbrota
    Kbrota over 7 years ago in reply to Andrew Beckett
    Thanks a lot, Andrew! I really appreciate your promptest response!
