  3. Wire Width - OA
  • Views 2000
Wire Width - OA
RoiZanoNew
RoiZanoNew over 16 years ago
Could some one help me with operation code.
I need a opertion that find the wire width during the creation of the wire and when selected.
 (in path we could find it under : le0PathForm->pathWidth->value )
 Roi.
    Hi Roi,
    Can you please clarify your question, as it doesn't really make sense.
    If you want to find the width of a selected path, just do:
    car(geGetSelSet())~>width
    Perhaps if you explained what you need the information for - what the purpose is - then your question  may make sense?
  • RoiZanoNew
    HI Andrew,
    There is a sense when you are creating wire and during that you want to change his params .
    by the function that i sent above you can get the param of the item during the creation of a path like  width or metal.
    I need the same operation but in "Wire" not in "Path"...
    This you could Find by:
                       a=hiGetCurrentWindow()
                       cmnd=hiGetCurrentCmd(a)
    Those Opertions give you the Cummand you are now.
    Buttom line .. I need the way to find the the width of the Wire during Editing.
    Thank you for the Fast Respond.
    Roi.
  • kbhow
    kbhow over 16 years ago
    Hi Roi,
    I believe Andrew had already answer your question. Wire is also known as "pathSeg".
    To get the width, you just need to get the ID of the wire (eg: wire_id), then wire_id~>width
    Perhaps you can tell us/eleborate what exactly you are trying to do.
    Regards
    How
