  3. can we map the tree to the tree table form
  • Views 15566
posh
posh over 16 years ago
Hi
I have a doubt that can we map the tree that displays the design hierarchy to a treetable form (ex: hiCreateTree() ) and put a callback function for the hierarchy to change the lib/cellname/viewname in that form.
    It probably doesn't make any sense to start from the results of leHiTree() - it would be awkward to intercept, and then you'd have to parse the output it produces (from the window it puts it in). Easier to traverse the hierarchy yourself, and build the hiCreateTree form yourself.
    You could base it on my Cadence Online Support Solution 11300048 . This is to do a tree on a schematic hierarchy (layout is simpler, because you don't need to worry about view switching). But you may find it a useful starting point.
  • posh
    I truely appriciate the kind of response this forum has got.
    thankyou very much
    Regards
    Harish
