  3. Help on leHiCreateMPP() command
  • Views 15186
Vignesh054
Vignesh054 over 16 years ago
 Is it possible to Create MPP with out using mouseAddpt() using leHiCreateMPP() function?
I want get the co-ordinates from the user and draw the MPP.
Vignesh T K
  • kbhow
    kbhow over 16 years ago
    Hi Vignesh,
    You can try use rodCreatePath
    How
    Hi Vignesh,
    You can use enterPoints() or enterPath() to digitize the points - collect them from the user. And then you can draw the MPP from an existing template using the SKILL code in Cadence Online Support Solution 11323850
    You may find looking at that code useful anyway (it uses rodCreatePath).
