  3. How to change from one layer to other layer
  • Replies 15
  • Subscribers 152
  • Views 27710
sailesh
sailesh over 16 years ago
 HI ,
      i need the code to change the metal layers in layout, EX: when the code is loaded all the M1 layers in layout should be replaced by M2 automatically. iam able to do till gettin the available layers..but iam not able to replace them
  • Rahul Biradar
    Rahul Biradar over 10 years ago
    I'm not able to write the code for the hierarchical layer replacement please help me as I'm a beginner with skill programming..
  • theopaone
    theopaone over 10 years ago
    You can use leSearchHierarchy to find the objects and leReplace to update the layer.
    Andrew may have some hierarchy parsing code which he shares.
    Some untested code showing the idea of a recursive layer replacement rather than leReplace:
    procedure(CCFreplaceLayersHier(cv @optional (done makeTable('visited nil)))
     let((LP)
      done[cv]=t
      LP=car(exists(lpp cv~>lpps lpp~>layerName=="M1" && lpp~>purpose=="drawing"))
      ; if there are shapes, and this isn't a pcell submaster, and it can be reopened in edit mode
      when(LP~>shapes && !(cv~>superMaster) && dbReopen(cv "a")
        LP~>shapes~>lpp=list("M2" "drawing")
      ; recursively visit all the child masters
      foreach(master cv~>instanceMasters
        unless(done[master]
          CCFreplaceLayersHier(master done)
      t
  • Rahul Biradar
    Thank you for your replies
    hi Andrew Beckett
    the below code is not working but it's executing...... please help me with this
     let((LP)
      done[cv]=t
        unless(done[master]
      t
    I just tried the code above, and it worked for me. I have a technology where the layers are called M1, M2 etc - you'd obviously have to change the layer names in the code if they're called something different.
    Then I opened the top level layout, and used:
    CCFreplaceLayersHier(geGetEditCellView())
    Note however that the code won't replace M1 used in MPP (multi-part path) or in vias, or inside PCells. Of course, I have no idea what the extent of what you're trying to do is...
