  3. How to change from one layer to other layer
  • Replies 15
  • Subscribers 152
  • Views 27709
sailesh
sailesh over 16 years ago
 HI ,
      i need the code to change the metal layers in layout, EX: when the code is loaded all the M1 layers in layout should be replaced by M2 automatically. iam able to do till gettin the available layers..but iam not able to replace them
  • kbhow
    kbhow over 16 years ago
    Hi Sailesh,
    Since you managed to get the layer. it will be easy for you to replace the metal layers.
    Example of changing a selected shapes from M1 to M2 on current cell view:
    selected_obj = geGetSelectedSet()
    foreach( obj selected_obj
        when( obj_id~>layerName == "M1"
            obj_id~>lpp = list("M2" "drawing")
        );when
    );foreach
     This is just an example to show you a simple way in changing the layer. You may write a routine for this. Happy coding.
    How
  • babji
    babji over 16 years ago
    if you want to replace all the M1 layers in the current cellview (Selected or unselected) then do this.
     prog( ()
    when(  geGetEditCellView()->mode == "r" println( "Need write access" ) return() );when
     foreach( shape geGetEditCellView()->shapes
        when( shape->layerName == "M1"   ; or shape->lpp == list( "M1" "drawing" )
            shape->lpp = list( "M2" "drawing" )  ; or shape->layerName = "M2"
        );when
    );fch
    );prog
    It's even easier than this. You could just do:
    geGetSelSet()~>layerName="M2"
    This avoids the need for the foreach loop. You can use a list of objects with the "squiggle" operator.
  • babji
     How about if we want to change all M1 shapes (Selected or not, level 0) can we do this.
    setof(  X geGetEditCellView( )~>shapes  X~>lpp == list(  "M1"  "drawing" )  )~>lpp = list(  "M2"  "drawing"  )
  • skillUser
    skillUser over 16 years ago
    You could, though it would be more efficient to find the matching lpp object first and then find its shapes, then iterate over those shapes to change the layer and purpose.  I don't have an example to hand, but it would be something like the following:
    m1lpp = car(setof(lpp geGetEditCellView()~>lpps lpp~>layerName=="M1" && lpp~>purpose=="drawing"))
    foreach(shape m1lpp~>shapes shape~>lpp=list("M2" "drawing"))
    Typically the number of shapes to process is an order of magnitude or more greater than the number of distinct layer-purpose pairs, hence the probable efficiency gain. YMMV depending on the design of course.
    Lawrence.
    Yes, although generally you'll be better off doing:
    car(exists(lpp cv~>lpps lpp~>layerName=="M1" && lpp~>purpose=="drawing"))~>shapes~>lpp=list("M2" "drawing")
    For big cellViews, there will be fewer LPP objects than shapes, so you end up traversing a smaller list. For small cellViews, it makes no difference, so it's safer to use the LP-based approach.
  • skillUser
    I should point out that Andrew's response is even more efficient since my example shows the use of foreach to iterate over the shapes to change their lpp, where really you can have a list on the left-hand side of the = when using the ~> operator and update the lpp for all items in the list in one hit (as babji also showed in their post).
    Lawrence.
  • Rahul Biradar
    Rahul Biradar over 10 years ago
    Hi how to use the above code for hierarchical layer replacement ?? regards rahul
  • theopaone
    theopaone over 10 years ago
    It is just another big loop.
    You need a list: processed cellViews
    Start of processing loop:
    Change layers in the current cellView.
    Save the cellView
    Add its name to the list of processed cellViews.
    You have to find all the instance masters in the current cellView (cvId~>instHeaders~>master)
    Close the cellView (this minimizes the number of open cellViews)
    for each master not in the list of processed cellViews
    Open the master for append
    Do the processing loop in the master
    Keep processing the masters till all are done
    End of processing loop
    From an architecture standpoint, the loop should be in a function and called recursively.
    Or you could just use leReplace().
