  3. Draw many Rect/Polygons of Many layers Interactively and...
  • Subscribers 152
  • Views 5565
Draw many Rect/Polygons of Many layers Interactively and selectively using Skill
Satya
Satya over 16 years ago
Hi All !!
I am again here with some new problem and expecting suggestion and  help from all of you.
 Now I would like to draw polygons/rectangales of one or more layer interactivley at the same time, Also If the layers alredy present want to delete the layer interactively using skill. Please help to do this...
Thank you in advance,
Satya
    Hi Satya,
    Use enterBox() to prompt the user for the location of the rectangle(s), maybe with an options form to control which layer names to create the rectangles on, and then in the doneProc of the enterBox use dbCreateRect to create the rectangles.
    Your requirement to delete existing shapes is rather imprecise - but that's just a matter of using dbDeleteObject on any shapes you want to delete.
    This seems pretty straightforward, and a little research (in the documentation, in this forum, and on Cadence Online Support) could have found you the answers to all of this. Perhaps your requirements are really more complicated? Or perhaps you just wanted somebody to write the code for you?
  • Satya
    Hi Andrew!!
    Thanks for the reply...Actually I wanted to know how better I can do it. But here  the no of layers are almost 5-16 or more ,
    I would like to draw them simultaneosly and selectively also same for deletion.
    Ninge
  • Quek
    Quek over 16 years ago
    Hi Satya
    The following is a sample of how you can do it. Load the script and enter "CCSgetPoints()" in ciw. Draw a few lines in a layout and press Enter to terminate.
    The script actually has a problem in that it is quite inflexible in terms of changing the input layers. Would you like to improve on it and post your solution so that everybody can benefit from it? Perhaps you might want to consider using "@rest" keyword in CCSgetPoints procedure to allow user to enter the desired layers.
    Best regards
    Quek
    procedure( CCSgetPoints()
       let( (orgSnapMode)
          orgSnapMode=hiGetCurrentWindow()->snapMode
          hiGetCurrentWindow()->snapMode="anyAngle"
          enterLine(
             ?prompts list("Enter first point" "Enter next point(s)")
             ?doneProc "CCSdraw"
          ) ;enterLine
          hiGetCurrentWindow()->snapMode=orgSnapMode
       ) ;let
    ) ;procedure
    procedure( CCSdraw(win done allPoints)
       let( (cv)
          if( done then
             cv=geGetWindowCellView()
             dbCreatePolygon(cv list("Metal1" "drawing") allPoints)
             dbCreatePolygon(cv list("Metal2" "drawing") allPoints)
             dbCreatePolygon(cv list("Metal3" "drawing") allPoints)
          ) ;if
       ) ;let
    ) ;procedure
  • Satya
    Thank you somuch Querk,
    as soon as I completed the task, definetely I'll share with you all.Once again, "All" Thanks  for your kind suggestions and help.
     Satya
