  3. Assigning a net name from schematics
  • Replies 10
  • Subscribers 150
  • Views 26314
bharath2k4er
bharath2k4er over 16 years ago
 Hi All,
        Recently i came accross a requirement to assign net names to all the nets from schematics..Is this possible to do in skill..? Pls provide me some inputs to work on..
Ex: For an inverter i/p net name is A & o/p is B in sch
                Layout also should have the netname A to the input & B to the output
Bharath.
    Hi Bharath,
    The way to do this in a schematic is to use schCreateWireLabel. If you just attach nets to wires, or change the name of a net, it will get lost next time you do a "check" operation, so the only sensible way is to label the wires.
    Here's some very old code which uses this approach - hopefully you can get the idea from this. It was to label any unlabelled nets, and was originally done before there was a mode where you could name nets automatically based on what the net was connected to, rather than just the simple "net1", "net2" type approach:
    /* abAddWireLabels.il
    Author A.D.Beckett
    Group Structured Custom, Cadence Design Systems Ltd
    Machine SUN
    Date Nov 29, 1993
    Modified
    By
    Creates wire labels on nets that have been named by
    the extractor. This means that more meaningful names
    can easily be added.
    SCCS Info: @(#) abAddWireLabels.il 11/20/08.15:26:10 1.1
    * (abRankDirection direction) *
    * Given a direction, return a rank number where the highest *
    * is the most preferred pin direction. *
    (procedure (abRankDirection direction)
    (case direction
    ("input" 1)
    ("inputOutput" 2)
    ("output" 3)
    (t 0)))
    * (abAddWireLabels) *
    * Automatically add wire labels to a schematic on the nets *
    * which have been named by the extractor *
    (procedure (abAddWireLabels @key (prefix "net") (separator "_") (snap 0.0625)
    (height 0.03125) (font "stick")
    (justify "lowerLeft") (orient "R0")
    (cellView nil))
    (let (prefixLength pinCentre inst xy labelText wire bestTerm)
    (setq prefixLength (strlen prefix))
    (unless cellView (setq cellView (geGetEditCellView)))
    (if (lessp (compareTime (dbGetq cellView lastSchematicExtraction)
    (dbGetq cellView instancesLastChanged)) 0)
    (progn
    (hiDisplayAppDBox
    ?name 'abAWLschematicChanged
    ?dboxBanner "Schematic Changed"
    ?dboxText "Schematic has been changed since last extraction"
    ?dialogType hicMessageDialog
    ?buttonLayout 'Close)
    nil)
    (progn
    (foreach net (dbGetq cellView nets)
    (when (zerop (strncmp (dbGetq net name) prefix prefixLength))
    (setq bestTerm nil)
    (foreach term (dbGetq net instTerms)
    (when (greaterp (abRankDirection (dbGetq term direction))
    (abRankDirection (dbGetq bestTerm direction)))
    (setq bestTerm term)))
    (when bestTerm
    (setq pinCentre
    (abGetPinCentre (dbGetq bestTerm term) snap))
    (setq inst (dbGetq bestTerm inst))
    (setq labelText (strcat (dbGetq inst name)
    separator
    (dbGetq bestTerm name)))
    (setq xy (geTransformUserPoint
    pinCentre
    (list (dbGetq inst xy)
    (dbGetq inst orient))))
    (setq xy (list (plus snap (xCoord xy))
    (plus snap (yCoord xy))))
    (setq wire
    (car (dbGetq (dbGetq bestTerm net) figs)))
    (when wire
    (schCreateWireLabel cellView
    wire
    xy
    labelText
    justify
    orient
    font
    height
    nil)
    (foreach label (dbGetq wire children)
    (when (equal (dbGetq label theLabel)
    labelText)
    (dbSetq label t abAutoLabel)
    t)
    * (abDeleteWireLabels) *
    * Delete all the labels which have been added automagically *
    (procedure (abDeleteWireLabels @key (cellView nil))
    (foreach shape (dbGetq cellView shapes)
    (when (and (equal (dbGetq shape objType) "label")
    (dbGetq shape abAutoLabel))
    (dbDeleteObject shape)))
    t)
    * find the centre of the pin in question, and *
    * snap it to the grid *
    (procedure (abGetPinCentre term snap)
    (let (centre)
    /* get the centre of the pin */
    (setq centre (centerBox (car (dbGetq (dbGetq
    (dbGetq term pins) inst) bBox))))
    (setq centre (list
    (times (round (quotient (xCoord centre) snap)) snap)
    (times (round (quotient (yCoord centre) snap)) snap)))
    centre))
  • bharath2k4er
    Andrew,
    My end result is not modifying the schematics, But assign the property called 'net name' to all the polygons in the layout. The name of the net in the layout will be corresponding net name in the schematics.
    Attached a screen shot for your reference..
    Bharath.
    Hi Bharath,
    Sorry, your original question was really unclear - you were talking about assigning net names in the schematic.
    Anyway, to get net names on the shapes in the layout, the simplest approach is to use Virtuoso Layout Suite XL.
    BTW, there was no screenshot in your previous post.
  • bharath2k4er
    I dont have virtuoso XL license.. Is there any alternate option..?
    Attached it once again. Have a look at it.
    Bharath.
  • bharath2k4er
    Andrew,
    I don't have the XL licensce. Can i code this in the current version..? Just for my curiosity, how will XL version assign net names to the polygons/paths in layout corresponding to same net name in schematics..?
    bHarath
  • bharath2k4er
     attached !
    Hi Bharath,
    Virtuoso Layout Suite XL is connectivity-aware. It has an extractor which is triggered by any changes to the layout, and will continuously re-extract the layout connectivity, following rules in the tech file as to how things are supposed to be connected.
    There's also a "binder" which takes care of figuring out which devices and nets are which between the schematic and layout. If you like, it's an on-line LVS. With IC613/IC614 this binder is much smarter than it was in IC5141 (which relied on the instance names matching between schematic and layout).
    You could of course write your own extractor (hard enough - although there have been some other threads recently talking about this - Derek has made some particularly useful appends on this subject), but you'd also have to get it to LVS too to match the extracted nets with the schematic. You may be able to use information from whatever LVS tool you are using to aid with this.
    But it seems a lot of work to do when there's a tool already which does this!
    Unfortunately I can't open the attachment - I get an error (I have an IT ticket open for this, which I'll chase).
  • bharath2k4er
    Andrew,
                     I wanted to add net names to already LVS clean layout. This will make my future edits simple. Can you assist how to do that.. For the new layouts, i have got a tool NDL (Net Driven Layout) which will automatically creates net names while drawing layouts.
    Bharath.
    Hi Bharath,
    I can't really help. It's a very large amount of work (and answering in this forum is not part of my job - I do it in my spare time), and as I said, Cadence already provides a tool to do this. What is this "NDL" tool you're talking about? Is this something home-grown or a third-party tool?
    I also outlined what the general way to solve this is, and pointed you at another thread which is talking about extraction.  Also, if  you're going to utilize your LVS tool to glean net information, perhaps using the extracted view from that LVS tool (you didn't say what tool it was) might be an easy way for a reviewer to find his way around the layout.
