  3. Cadance crashes while executing SKILL application: Insufficient...
  • Views 14331
Cadance crashes while executing SKILL application: Insufficient memory to continue.
ToMWUT
ToMWUT over 16 years ago
Hello All,
I’ve got a problem with my SKILL application executed in CIW Cadence. This is a big program which uses a lot of resources. But it runs on a very fast machine: 32GB RAM and 4 dual core CPUs. The problem occurs when the application runs for over 3 days and Cadence crashes with information:
Cannot satisfy request for 65536 more bytes of memory.
Terminating process.
I may only add that, when I last checked the percentage of memory used by my application it was only 4-5% of all available RAM resources – so I don’t think this is a system problem… I don’t know the amount of memory used by application exactly when it crashes…
Another strange thing is that, when I executed different SKILL application, but also resources consuming it crashed with the same error message and even with the same amount of memory mentioned (65536)
Any ideas?
ToM
