  3. How do I parse a text file for coord pairs?
  • Views 16123
Vaughn
Vaughn over 16 years ago
I want to read a file and return a list of all the coord pairs in the file. Due to the unknown seperator between coord. I want to return any two number pairs per line.
I can use the while command to parse strings but am unable to find how to parse for numbers while reading a file.
  • dmay
    dmay over 16 years ago
    Take a look at a post I made earlier this month:
    /forums/p/14625/24977.aspx#24977
    Assume the variable line has one line from the file. Then run the following code to store the coordinates in variable coord:
            rexCompile( "[xyXY] *[=:]")
            coord = rexReplace( line " " 0)
            rexCompile( "[(){}=,:]")
            coord = rexReplace( coord " " 0)
            rexCompile( "\\. ")
            coord = parseString(coord)
            ;Get only the numbers from the rest of the data
            coord=mapcar( 'aelNumber coord)
            ;Keep non-nil values
            coord=setof(x coord x)
    Derek
  • Vaughn
    Thanks Derik!!
    Can someone explain what this line is doing?
    Where can I find instructions or examples of what rexCompile considers regular expressions?
  • dmay
    The square brackets are used to specify a possible set of matches. This particular line finds any one of the following:
    x=
    X =
    x:
    y:
    Y   =
    The following rexReplace will remove the X= or X: or Y= or Y: and replace it with a space. What the code is doing is trying to remove any characters that might be next to a number without a space. It is very common for x=1 to appear or y:3 to appear. The regular expression is replaced with a space so we can run the parseString in a later step.
    This will find and replace the equal sign, parentheses, commas, braces and colons. Again the goal is to isolate the number.
     rexCompile( "\\. ")
    The removes a period followed by a space to differentiate a float from an integer.
    Derek
  • Vaughn
     Thanks again Derek!!
    In what manual/web page can I find instructions on regular expressions for skill?
    They are very useful.
     Vaughn
  • dmay
    In the Skill Language User Guide, look for "Pattern Matching".
     Derek
