  3. Single Via Contact to Double Via Contact
  • Replies 10
  • Subscribers 152
  • Views 20957
zeroskills
zeroskills over 16 years ago
Our default Via Contact is only single when instanciated, is it possible to have a skill code that can be attached to a bindkey that when a Via Contact is instanciated, it will be doubled?
Instead of using Window or Bindkey - "Create Contact" to double or multiple contact by changing Row or Column, is it possible to have a code when used with a bindkey automatically call a M1M2 Via Contact 1x2?
  • babji
    babji over 16 years ago
    For IC5.1.41,
    If you have access to sourcelink then Solution ID:11115668 would be good start.
    or
    Please make the following changes in the ".cdsenv" file to achieve the desired.
    1)  layout contactDefFromTechfile boolean nil
    2) layout contactColumns int 2
    Similarly you can use the below variables to do various default settings on the form :
    layout contactDelX float 0.0
    layout contactDelY float 0.0
    layout contactResetDelXY boolean t
    layout contactResetXYBias boolean t
    layout contactResetRowCol boolean t
    layout contactRows int 3
    For details on the envsetval function please refer the below doc :
    http://sourcelink.cadence.com/docs/files/Release_Info/Docs/skuiref/skuiref5.0/skuiref.pdf
  • zeroskills
    Thanks. I did found the same solution afterwards, at first my .cdsenv wasn't loading properly so i thought something wrong until i load it directly from my .cdsinit.
    Thanks for the help.
    On the same question,
    is it possible to  instanciate directly  a via contact without  opening or using  the "create contact"tool? for instance, by pressing "ctrl + 1" bindkey, i can instanciate a m1m2 via directly.
  • babji
    There are many ways we can automate this. most simple ways would be
     dbCreateSimpleMosaicByMasterName( deGetCellView()
                                                techGetTechLibName( ddGetObj( deGetCellView()->libName ))
                                                "via2"
                                                "symbolic"
                                                nil
                                                enterPoint()
                                                "R0"
                                                1
                                                 2
                                                 1.26
                                                 1.26
    or
    procedure( ViaCreate( viaName )
    let( ( via2 llx lly urx ury )
     via2=dbOpenCellViewByType(
                                                viaName
                                                "symbolic"
     urx = xCoord( upperRight( via2->bBox ))
     ury = yCoord( upperRight( via2->bBox ))
     llx = xCoord( lowerLeft( via2->bBox ))
     lly = yCoord( lowerLeft( via2->bBox ))
     dbCreateSimpleMosaic(
                        deGetCellView()
                        via2
                        nil
                        enterPoint()
                        "R0"
                         2
                         2
                        urx-llx
                        ury-lly
    dbClose( via2)
    );let
    );proc
    Bind this to ctrl+ bindkeys.
    or
    Auto-Contact feature is sufficient most of the times. In IC6 it works for paths & polygons.
  • zeroskills
    Thanks Babji,
    I tried your 1st code. i guess there's missing something, it's not working.
    I relpaced "libName" - "our libName" (where the via is) and "via2" - "MT_AM" (which is the via i wanted to use)
    I also added this bindkey to the code:
    hiSetBindKey("Layout" "Shift<Key>i" "dbCreateSimpleMosaicByMasterName()"
    Your 2nd code,
    same thing, i changed "libName" - "our libName" (where the via is), viaName - "MT_AM" (which is the via i wanted to use).
  • babji
    Do this..
                                       viaName
                                       "symbolic"
                                       nil
                                       enterPoint()
                                       "R0"
                                                1
                                                2
                                                3.24
                                                1.26
     );procedure
     hiSetBindKey("Layout" "Shift<Key>i" "ViaCreate( \"MT_AM\" )" )
     Yes you will get 2 vias when flattened. Obvious since you are placing an array of vias. I don't know how to place vias similar to  "Create Contact...".
  • PSRK
    PSRK over 15 years ago
     I'm using the below constraint in the vcar rules file  before exporting. The VCAR is placing single via while routing
        list( '("tsmc18rf" "M2_M1" "symbolic") t)
    But I dont know the rule to keep double contact/via in the router .Please help me.
    Siva
  • harris3
    harris3 over 15 years ago
    Siva,
     I don't know about adding a constraint before starting the router.  I load a ".do" file in the router to make the routing of all of the nets use a 2x1 via array.  The do file contains the following command:
    select all nets
    define (class allnets (selected))
    unselect all nets
    circuit class allnets (use_via (use_array M2_M1 2 1))
    -Phil
  • Arnaud31
    Arnaud31 over 13 years ago
     Searching how to have automatically double via with "create contact" tool, I found this forum and your solution. I've added the two lines as you explained and now I have automatically double via. Very good solution and easy change.
     But now, if I instanciate a M2M1 contact and then a M1Poly contact which contact spacing is different, the deltaX and Y are not updated as before. For information, the width and the length are automatically updated.
    Is it possible to have both automatically double via and the delta X/Y updated automatically?
       Thank you for your help.
    It's not clear which version you're using or which "two lines" you are referring to (to me anyway).
    I don't really understand your problem. Probably best to start a new thread rather than appending to an old one (as the Forum Guidelines clearly advise you not to do).
  • Arnaud31
       Hello Andrew,
     I understand that a new discussion would be better but my problem is the same as explained one in this old topic and my message was a reply of  Babji one posted the 5th of february 2010.
     I will try to be clear.
    First, I use IC5.1.41.
    My question : Default via contacts are single when instanciated with Create Contact tool. Is there an easy solution to have automatically double via contact when instanciated?
    Solution : in this discussion, Babji suggested to make the following changes in the ".cdsenv" file.
    So I did it from my .cdsinit and I have automatically double via but now if I change the contact type which contact spacing is different, the Delta X and Delta Y parameters are not updated to follow the technology rules.
    New question : is it possible to have automatically double via contact when instanciated with Create Contact tool without changing the other parameters that follow technology rules?
