  3. change the "style" (width) of the ruler
  • Replies 7
  • Views 4665
The Consultant
The Consultant over 16 years ago
Is there a possibility to change it ?
    Not as far as I know. I wondered whether it might be possible in IC614 where rulers are stored persistently, but there doesn't appear to be a width attribute.
    You should contact customer support and request and enhancement.
    Best Regards,
  • The Consultant
     ok,
    so what can i change about the ruler ?
    In IC614 they can be stretched and moved - probably reshape too (I didn't try) because you can select vertices of the ruler.
    Not sure what else you want to change?
  • The Consultant
     i have "only" 613. was worth the try.
    Thx.
  • dmay
    dmay over 16 years ago
    Actually, it appears that the ruler is the lpp "hilite drawing4" (at least in 5.1.41). So you can change the color and line style using the display resource editor.
     Derek
    Good point. I was think too much of changing the actual object in IC614 (too
    close to the software!)
    Altering the display resource file should impact the appearance (in both
    releases), but of course that will be global, rather than per-ruler.
    > Derek
    > You received this email because you subscribed to notifications for the
    > Cadence Custom IC SKILL Forum. To unsubscribe, log in, go to forums, and
    > change your forum subscriptions.
    > http://www.cadence.com/community/forums/ForumSubscriptions.aspx
  • The Consultant
     Works fine in 613 too.
    thx. dmay
