  3. search & replace in a sting
  • Subscribers 153
  • Views 11767
The Consultant
The Consultant over 16 years ago
string="1!2! 3 4"
should become
string="1234"
 so remove all " " and "!"
how can i do this
regex ?
    Since you're using IC613 (from your previous post), you could use the newer "pcre" (Perl Compatible Regular Expression) functions which are more powerful than the older "rex" functions. For example:
    pat=pcreCompile("[!\\s]")
    string=pcreReplace(pat string "" 0)
    The \\s (extra escape needed because the pattern really needs a backslash, but backslash is used in SKILL, so needs to be escaped) means whitespace. So it will match space, tab, etc.
    You could also use the older functions:
    rexCompile("[! ]")
    string=rexReplace(string "" 0)
    The PCRE-based functions are really powerful, and so I'd recommend those in general if you don't need to make code also work in IC5141 (which only had the older rex functions)
  • The Consultant
     that works fine.
    thx. Andrew
  • matturin
    matturin over 12 years ago
     I use the pcreCompile pcreReplace functions but i want to replace all white space in my string  with \| .
    test = "aaa bbb ccc"
     pat=pcreCompile("[\\s]")
     test=pcreReplace(pat test "\\|" 0)
    => "aaa|bbb|ccc" and not "aaa\|bbb\|ccc" .
    How can i do this ?  How can i put a "\"?
    Best Regards Mat.
  • Yunqi
    Yunqi over 4 years ago in reply to Andrew Beckett
    Hello Andrew,
    How to remember the pattern, and recall it back in the replacement?
    e.g. from "inst1.inst2/inst3/net4<5>#6"
    to "inst1.inst2\\/inst3\\/net4\\<5\\>\\#6"
    Can I use in this way:
    pat=pcreCompile("([/<>#])")
    string=pcreReplace(pat string "\\\\$_" 0)    ; How about similar $1 or $_?
    Yunqi
    Andrew Beckett over 4 years ago in reply to Yunqi
    I split off your earlier question from this thread (you'll see why when you read the forum guidelines which I linked to in your reply). See the split thread here. Please stop re-askng the question in this 12-year old post.
