  3. overlap of metals
  • Views 17218
overlap of metals
sailesh
sailesh over 16 years ago
Hello all,
                Iam trying to find the overlap of two metals, if it is overlap of M1 & M2 then placing via1,  similary for M2 & M3. I tried with ovelap command, but iam not able to get it. can any one help me
     How about using dbLayerAnd?
  • sailesh
    Hello Andrew
    I have used that but it showing as undefined function
    What version are you using? (Help->About in the CIW)
  • sailesh
    HI andhrew ,
        iam using 5.1.0 version of icfb
    That's not what is reported from Help->About - what I wanted to know was the subversion.
    My guess is that you're using a version prior to IC5141 USR1 (which was released in December 2004) - because that's when dbLayerAnd() was introduced. If so, the solution is to use a more recent subversion of IC5141.
