  3. A skill function or skill routine to readout a CDF Parameter...
  • Views 16996
A skill function or skill routine to readout a CDF Parameter from an instance!
Peach99
Peach99 over 16 years ago
I want to know, how I can readout a CDF Parameter of an Instance (on an appointed schematic)! Is there a skill function or a skill routine, who can do this? I only need a skill description! I can't find out, how I can do this!!
best regards
Daniel Pietsch
    Hi Daniel,
    If  you have CDS_Netlisting_Mode set to "Analog" you can do:
    instId~>myParamName
    and it will retrieve the CDF value on that instance - this is either the instance property (if set) or the default from the CDF (if no instance value is on the instance).
    Alternatively you can use:
    cdf=cdfGetInstCDF(instId)
    cdf->myParamName->value
  • Peach99
     How I can get the Instance ID??
    Peach99
  • dmay
    dmay over 16 years ago
    There are several ways to do this.
    If the instance is selected:  instId = car(selectedSet())  or  css()
    instId = dbFindAnyInstByName(geGetEditCellView() "myInstName")
    All the instances in the cellview are here:  geGetEditCellView()~>instances
    Derek
    Just wanted to point out that css() is a private SKILL function, and should not be used in code as it is liable to be removed at any point. selectedSet() is not documented; it's only there for legacy reasons (compatibility with Edge/Artist (pre-DFII) code) and whilst is not strictly private, you should not really use it.
    The public functions are called geGetSelSet() and geGetSelectedSet().
