  3. re-eval contacts
  • Views 15460
re-eval contacts
nuSkill
nuSkill over 16 years ago
Hi guys,
 I am using ICFB5.1.41_USR4 and I created instances of pcells and contacts using dbCreateParamInstByMasterName. I got the layout that I want but the contacts` Rows and Columns parameter values are both "0" once checked on the properties window although I have the correct contacts layout based on what I specified on the l_params options during generation.
I needed to use dbCreateParamsInstByMasterName because I have to specify the instance name, otherwise I could just use leCreateContact but you cannot assign instance name using this (saved on the ROD tab).
 Do I need to re-evaluate my contacts to have the correct parameter values in the params window, same as what needs to be done for pcells? If so how can I do this? I am using the gpdk090 library.
 Thanks and best regards,
/Andal
    Andal,
    Sounds odd. Can you give an example piece of code with the all arguments to dbCreateParamInstByMasterName, so I can try it out?
  • nuSkill
     Here is a sample code with params.
    CreateParamInstByMasterName(CV "gpdk090" "M3_M2" "symbolic" "ROD_x20535_y18135" list(20.535 18.135) "R90" 1 list(list("column" "float" 3) list("row" "float" 5) ))
     I get a 3x5 via but once I do query of the via, the parameters window reflects "0" values for rows and column.
    Note that if I do not include the l_params I get a single via whose parameters are correctly reflected once I do a query.
    Could it be I get the syntax for the l_params wrong?
    Thanks for your help.
    /Andal
    Hi Andal,
    Use "int" instead of "float" for the row and column parameters. The type is wrong.
  • nuSkill
     Thanks alot! I knew it will be something so simple :(
     Best regads,
    /Andam
