  3. How to get overlap blockages!
  • Subscribers 150
  • Views 15711
kbhow
kbhow over 16 years ago
Hi All,
I was trying to get all overlap objects from the specified bounding box, but i failed to retrieve the info of blockages. I tried dbGetOverlaps, dbGetTrueOverlaps and its was failed to get any blockages.
Did anyone knows this is a bug? Do we have any of how to get overlap blockages?
Your suggestion and advice is much appreciated.
How
    I assume you must be using IC61? If so, you'd need to use dbLayerBlockageQuery() . It's not a bug - blockages are different kind of objects now (they're not just shapes on special layers). If using IC5141, dbGetOverlaps should have worked.
  • kbhow
    Ya, you are correct.I'm using IC611.
    dbLayerBlockageQuery is exactly what im looking for. Thanks a lot
    How
