  3. SKILL CODE OF MASTER Pcell
  • Subscribers 152
  • Views 16717
Sabyasachi
Sabyasachi over 16 years ago
Hi all,
 I am using cadence IC5141. I am using on National Semiconductors 180nm technology(CMOS9). There are some standard pcells in layout library.How to get the skill code of that pcells. When I am compiling to skill it is generating a file which calls the master instance.How to get the skill code of that master instance
Cheers
Sabyasachi
  • Quek
    Quek over 16 years ago
    Hi Sabyasachi
    SKILL codes for pcells in a pdk are confidential and will not be released. You will not be able to get them. Maybe you would like to describe more on what you are doing just to confirm if you really need the pcell codes.
    Best regards
    Quek
  • Sabyasachi
    Hi Quek If master pcell SKILL codes are not available then help me other ways. Then if I want to make a pcell where i will be calling those given pcells witth parsing parameters. How to do it . Please help with a short example
  • skillUser
    skillUser over 16 years ago
    Hi Sabyasachi,
    Your request is not clear at all, but it sounds like you might want to instantiate a PCell in another SKILL Pcell - if this is the case then there are two functions that you could use to do this:
    dbCreateParamInst and dbCreateParamInstByMasterName
    dbCreateParamInst(
        d_cellView
        d_master
        t_name
        l_point
        t_orient
        [ x_numInst
        [ l_params
        [ b_physOnly ] ] ]
        => d_inst | nil
    dbCreateParamInstByMasterName(
        d_cellView
        t_libName
        t_cellName
        t_viewName
        t_name
        l_origin
        l_orient
        [ x_numInst
        [ l_params
        [ b_physOnly ] ] ]
        => d_inst | nil
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/pcellref/pcellref6.1.4/skillPcells.html
    Check out the documentation on pcells (IC614 version).
    I hope that this helps.
    Lawrence.
