  3. how to get all the shell env value?
  • Subscribers 153
  • Views 24200
llobak
llobak over 16 years ago
 I know that we can read the shell env value by using getShellEnvVar("XYZ"). If i want to know ALL the shell env value, how can i do it with SKILL?
SL
  • Quek
    Quek over 16 years ago
    Hi SL
    Please refer to COS solution 1843362. There is no single cmd to do it. One possible method is to first dump the output of a system("env") cmd in a file and then re-read the file.
    Best regards
    Quek
  • ahamlett
    ahamlett over 16 years ago
    procedure( allEnvVars()
    let( (i v time line)
    v = makeTable("v" nil) ; create an association table to hold all the shell variables and their values
    time = stringToTime(getCurrentTime()) ; get current time as number
    if(system(sprintf(nil "env > /tmp/%n" time)) == 0 then ; run env command
    if(i = infile(sprintf(nil "/tmp/%n" time)) then ; open temp file containing output from env command
    while(gets(line i) ; loop through output of env command
    line = parseString(line "= ")
    if(length(line) > 0 then
    ;v[car(line)] = cadr(line) ; get env var's value from "env" output
    v[car(line)] = getShellEnvVar(car(line)) ; get env var's value using skill
    close(i)
    else
    printf("error when opening temp file ")
    else
    printf("error while running env ")
    deleteFile(sprintf(nil "/tmp/%n" time))
    v
  • llobak
     Thanks for the help from both of you. Actually i've already tried the method before, but I'm facing some problem as some of the env value that i can get from getShellEnvVar() command, I could not get it in unix by typing env. Can anyone enlight me why is it so? Thanks in advance.
    SL
    Maybe the environment variables are being set by:
    a) the virtuoso/icfb command wrapper
    b) the virtuoso/icfb executable itself (or even some SKILL code)
    c) some wrapper command you use to launch virtuoso/icfb
    If you launch env from within icfb, it should inherit anything that icfb is seeing.
    llobak wrote, on 03/11/10 21:02:
    > Regards,
    > SL
    > You received this email because you subscribed to notifications for the
    > Cadence Custom IC SKILL Forum. To unsubscribe, log in, go to forums, and
    > change your forum subscriptions.
    > http://www.cadence.com/community/forums/ForumSubscriptions.aspx
  • llobak
     Thanks for your explanation. I finally get it now. haha.
    To others,
     Thanks for all your help!
    SL
