  3. Integrate a lookup table and readout the values line by...
  • Views 16770
Integrate a lookup table and readout the values line by line
Peach99
Peach99 over 16 years ago
Hello I want to integrate a lookup table in skill and I want to readout the values line by line! According to which device is selected the function that I search should readout a designated line of the table! I think I can use the function "list" to create the table but I can't find out how I can do this and how I can readout a designated value in the list!
Regards
Daniel Pietsch
    Hi Daniel,
    There are several ways you could do this. One is to create your lookup in the file as an assoc list. For example:
      ("fred" 1)
      ("jim" 1 2 3)
      ("harry" 4 5)
    And then read it:
    fp=infile("lookup.txt")
    data=car(lineread(fp))
    close(fp)
    assoc("jim" data) => ("jim" 1 2 3)
    Or you could convert it into a table:
    tab=makeTable('dataTable nil)
    foreach(entry data
      tab[car(entry)]=cdr(entry)
    tab["harry"] => (4 5)
    Or you could use readTable/writeTable to read and write directly into the table - see the documentation for more details.
    Essentially both lists (e.g. using assoc lists) and tables (which are associative arrays, or hash tables) are good for lookup of data based on a key. Note that an assoc list is less efficient for large lookup tables, because it does a sequential search, whereas an association table (as produced by makeTable) hashes the key and is then faster to lookup (and uses a little less memory).
    Best Regards,
  • Peach99
    Thank you for the answer!
    Regards
    Daniel Pietsch
