  3. What the Environment variable of Stretch form option for...
  • Subscribers 152
  • Views 1581
What the Environment variable of Stretch form option for change 'keep connected' to "none"?
kfirc
kfirc over 16 years ago
I work with Virtuoso Layout editor ic6.1.4, I would like to know the Environment variable of Strech form 'keep connected' that the default value will be "None"?
kfir
     The default is actually "all". You can set it using this .cdsenv :
    layout keepWiresConnected cyclic  "none"
    The values can be "all", "spine" or "none".
    The equivalent SKILL is:
    envSetVal("layout" "keepWiresConnected" 'cyclic  "none")
  • berndf
    berndf over 16 years ago
     Andrew,
     maybe worth to mention for the community that this has changed from 6.1.3 to 6.1.4.
    In 6.1.3 it was
    envSetVal( "layout" 'keepWiresConnected 'boolean nil )
    Bernd
