  3. Design variables in skill
  • Views 14336
raduionescu
raduionescu over 16 years ago
Using the AMS plugin from the cadence hierarchy editor I set the values of certain user defined design variables. After I run a simulation or just save the current configuration, I would like to be able to access those values from a completly independent skill script, and i thought that these values were saved in some file by the AMS and i can just parse it and get the design var name and value, but I can't find such a file. Are these values written somewhere or ar they in some internal database of the AMS? The only place in which I found them was the cdsHED.log and I don't think that is a reliable source. Is there any way to get them and if yes, are they in a standar or use-defined run directory? I hope the question makes sense.
Radu
