  3. get custom via parameters Virtuoso version IC6.1.4.485
  • Views 15015
kfirc
kfirc over 16 years ago
I'm trying to get custom via (e.g. "M2_M1s")  parameters using techFindViaDefByName~>params
I got those parameters with standard via (e.g. "M2_M1") but with the cusom via, the params option doens't exist.
How can I get those parameters?
Kfir
  • kbhow
    kbhow over 16 years ago
    hi Kfir,
    If i'm not mistaken, although customVia is via, but it is consider an instance object. You can't get the parameters of the customVia.
    Rgds,
    How
  • lrl12skdev
    lrl12skdev over 16 years ago
    Im not sure if this could help you. I tried out already with stdViaDef as you can see below. just play around maybe it would work also for customVia.
    br,  rence
    viaRuleList = setof(viaD techGetTechFile(geGetEditCellView())~>viaDefs (viaD~>objType == "stdViaDef"))~>params
