  3. Create bindkey for display levels
  • Views 17251
custom
custom over 16 years ago
I'm trying to create a bindkey for Display Levels Start and Stop.  For example: if I used the + key to view one level down. If I hit the + key again I would then be looking at 2 levels down. If I hit the - key, then I would be looking at 1 level down. If I hit the - key again I would be at the 0 level.  Does anyone have an idea on how to do this?
 thanks,
Mark
  • dmay
    dmay over 16 years ago
    We have a routine that does this. You pass it an integer representing how much you want to change the depth. The bindkeys below use the +/- near the backspace. For the Keypad, you could use: <Key>KP_Add or <Key>KP_Subtract.
    Derek
    procedure(myShowHierDepth( @optional (step 1))
        let((curstep)
          curstep = hiGetCurrentWindow()->stopLevel
          curstep = curstep + step
          cond(
              (curstep > 20 curstep=20)
              (curstep < 0  curstep=0 )
          hiGetCurrentWindow()->stopLevel = curstep
        );let
    );procedure
    hiSetBindKey("Layout"         "<Key>=" "myShowHierDepth(1)")
    hiSetBindKey("Layout"        "<Key>-" "myShowHierDepth(-1)")
  • custom
    That worked perfectly.
    Great response time.
    Thanks Derek
  • lrl12skdev
    lrl12skdev over 16 years ago
    you can also do something like shown below so you dont need to load any skill routine.
    hiSetBindKey("Layout" "<Key>[" "hiGetCurrentWindow()->stopLevel = hiGetCurrentWindow()->stopLevel-1")
    hiSetBindKey("Layout" "<Key>]" "hiGetCurrentWindow()->stopLevel = hiGetCurrentWindow()->stopLevel+1")
     br,  rence
