  3. Create mulitpart path with 2 row of contacts
  • Views 19662
kbhow
kbhow over 16 years ago
Hi All,
Can we create a multipart path with 2 rows of contact? I was trying to customise the multipart path for 2 row of contact but failed. If there is way, how to do that, and what are the setting i needs to change?
Very thanks.
Rgds,
How
  • dmay
    dmay over 16 years ago
    You should be able to define two different sets of sub-rectangles with different offsets from the centerline of the path.
     Derek
  • skillUser
    skillUser over 16 years ago
     Hi How,
    I agree with Derek - the subpart for the rectangles will only create a single row/line so if you want two then create one on one side of the master path and another on the other side - effectively each will have the same values except the separation value will be +/- sep. If you are using the rodCreatePath() SKILL function, then in the ?subRect argument list there will be two subrectangle argument lists, one with ?sep with a positive value and the other with ?sep with a negative value.
    Hope it helps,
    Lawrence.
  • Prabhu The ICL
    Prabhu The ICL over 16 years ago
    Hi kbhow,  The following code was written for tsmcN65nm dfm purpose.
    You can change the values and they can be passed through some techfile skill functions.
    I tried to get the dfm values from the techfile but I am in vain.
    Anyways, this code may not be efficient but can be sufficient for you to bring an idea...
    procedure(points(bbox dl1 dr1 dt1 db1)
      let( (ll ur llx urx lly ury X Y my_list)
              ll =  lowerLeft( bbox )
              ur = upperRight( bbox )
              llx = xCoord(ll)
              urx = xCoord(ur)
              X = urx-llx
              lly = yCoord( ll )
              ury = yCoord( ur )
              Y = ury - lly
              my_list = list( llx+(X/2.0):-db1+lly urx+dr1:-db1+lly dr1+urx:ury+dt1 -dl1+llx:dt1+ury -dl1+llx:lly-db1 llx+(X/2.0):-db1+lly)
      );let
    );proc
    procedure( union( bBoxList )
    let( ( llxList llyList urxList uryList minllx minlly maxurx maxury )
      llxList = foreach( mapcar bBox bBoxList xCoord( lowerLeft( bBox )))
      llyList = foreach( mapcar bBox bBoxList yCoord( lowerLeft( bBox )))
      urxList = foreach( mapcar bBox bBoxList xCoord( upperRight( bBox )))
      uryList = foreach( mapcar bBox bBoxList yCoord( upperRight( bBox )))
          minllx = apply( 'min llxList )
          minlly = apply( 'min llyList )
          maxurx = apply( 'max urxList )
          maxury = apply( 'max uryList )
          list( minllx:minlly maxurx:maxury )
      ) ; let
    ) ; procedure
    procedure(my_gring_p(dl dr dt db flag val tap t_val)
      for(j 0 val-1
          if(j==0 then w=0.17 else w=0.17+(0.23*j))
    if(myForm~>AllSides~>value==
    nil then
      if(tap=="NTAP" then
          dl1 = dl + 0.26 +w/2
          dr1 = dr + 0.26 +w/2
          dt1 = dt + 0.26 +w/2
          db1 = db + 0.26 +w/2
      else
          dl1 = dl + 0.03 +w/2
          dr1 = dr + 0.03 +w/2
          dt1 = dt + 0.03 +w/2
          db1 = db + 0.03 +w/2
      );if
    else
      if(tap=="NTAP" then
          dl1=dr1=dt1=db1= t_val + w/2 + 0.26
      else
          dl1=dr1=dt1=db1= t_val + w/2 + 0.03
      );if
    );if
      if(flag=="Multiple" then
          foreach(box geGetSelSet()
              draw_ring_p(points(box~>bBox dl1 dr1 dt1 db1) val tap)
          );for
      else
      if(geGetSelSetCount()>1 then
          draw_ring_p(points(union(geGetSelSet()~>bBox) dl1 dr1 dt1 db1) val tap)
      else
          draw_ring_p(points(car(geGetSelSet()~>bBox) dl1 dr1 dt1 db1) val tap)
      );if       );if
    );pro
    procedure(draw_ring_p(points num tap)
    b1='()
    choose = list( list( ?layer list("M1" "drawing") ?enclosure  0.0 ?choppable t ?beginOffset -0.0 ?endOffset -0.0 )
    list( ?layer list("PP" "drawing") ?enclosure -0.03 ?choppable t ?beginOffset 0.0 ?endOffset 0.0 )
    list( ?layer list("NP" "drawing") ?enclosure -0.03 ?choppable t ?beginOffset 0.0 ?endOffset 0.0 )
    list( ?layer list("NW" "drawing") ?enclosure -0.26 ?choppable t ?beginOffset 0.0 ?endOffset 0.0 ) );listend
      if(tap=="NTAP" then
          l1 = list( nth(0 choose) nth(2 choose) nth(3 choose) )
      else
          l1 = list( nth(0 choose) nth(1 choose) )
      );if
      for(i 0 num-1
          if(i==0 then sep=-0.13 W=0.17 else sep=-0.13-(0.23*i)  W=0.17+(0.23*i))
    b1 = cons(list( ?layer list("CO" "drawing") ?width 0.09 ?length    0.09 ?choppable    t ?sep sep ?justification "left" ?space    0.15 ?beginOffset -0.07 ?endOffset -0.07 ?beginSegOffset 0.0 ?endSegOffset 0.0 ?gap "distribute" ) b1)
      );for
    rodCreatePath(
          ?cvId     deGetEditCellView()
          ?layer     list("OD" "drawing")
          ?width     W
          ?choppable     t
          ?pts         points
          ?encSubPath l1
          ?subRect    b1
           );rect
    );proc
    procedure(createRingForm()
     let((guardType myForm  enclosedBy )
     guardType = hiCreateRadioField(
                        ?name 'guardType
                ?choices list( "Single" "Multiple")
                ?defValue "Single" ); hiCreateRadioField
     enclosedBy = hiCreateFloatField(
              ?name 'enclosedBy
              ?defValue 0.5
              ?enabled nil
     enclosedBy_l = hiCreateFloatField(
              ?name 'enclosedBy_l
              ?prompt "Left ... "
              ?defValue 1.0
              ?enabled t
     enclosedBy_r = hiCreateFloatField(
              ?name 'enclosedBy_r
              ?prompt "Right ... "
              ?defValue 1.0
              ?enabled t
     enclosedBy_t = hiCreateFloatField(
              ?name 'enclosedBy_t
              ?prompt "Top ... "
              ?defValue 1.0
              ?enabled t
     enclosedBy_b = hiCreateFloatField(
              ?name 'enclosedBy_b
              ?prompt "Bottom ... "
              ?defValue 1.0
              ?enabled t
     num_co     = hiCreateIntField(
              ?name 'num_co
              ?prompt "No. of Contact Rows ... "
              ?defValue 1
     TAP        = hiCreateRadioField(
                        ?name 'TAP
                ?choices list( "NTAP" "PTAP")
                ?defValue "NTAP" ); hiCreateRadioField
     AllSides        = hiCreateBooleanButton(
                        ?name 'AllSides
                ?buttonText "AllSides"               ?defValue nil
                ?callback "if(myForm->AllSides->value then myForm->enclosedBy_l->enabled=myForm->enclosedBy_r->enabled=myForm->enclosedBy_t->enabled=myForm->enclosedBy_b->enabled=nil myForm->enclosedBy->enabled=t else myForm->enclosedBy_l->enabled=myForm->enclosedBy_r->enabled=myForm->enclosedBy_t->enabled=myForm->enclosedBy_b->enabled=t myForm->enclosedBy->enabled=nil)"
     myForm= hiCreateAppForm(
              ?name 'myForm
              ?fields list(
                       list(enclosedBy_l 0:0 260:25 200 )
                       list(enclosedBy_r 300:0 260:25 200 )
                       list(enclosedBy_t 0:30 260:25 200 )
                       list(enclosedBy_b 300:30 260:25 200 )
                       list(num_co 0:60 260:25 200)
                       list(guardType 0:90 260:25 200 )
                       list(TAP 300:90 260:25 200)
                       list(AllSides 0:120 260:25 200)
                       list(enclosedBy 300:120 260:25 200)
              ?formTitle "A SoC Guard Ring form ..."
              ?callback "my_gring_p(enclosedBy_l~>value enclosedBy_r~>value enclosedBy_t~>value enclosedBy_b~>value guardType~>value num_co~>value TAP~>value enclosedBy~>value)"
              ?buttonLayout 'OKCancelApply
              ?initialSize t
     hiDisplayForm(myForm)
      );let
    );proc
    createRingForm()
    ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;ends here;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
     Best Regards...
    Prabhakar. K --- The ICL Engineer
    SoCtronics
  • kbhow
    Hi All,
    Really thanks a lot for the advice and great helping hands. Let's me have a try and return back if there is any issue.
    Rgds,
    How
    One point to Prabhakar. It's really good practice to use a prefix (we recommend an uppercase prefix to avoid clashing with Cadence functions), in order to distinguish between various code. For example, if you and colleagues write various applications, there's quite a high chance of creating functions called things like points() or union(). If your functions were called SOCcreateGuardPoints() and SOCcreateGuardUnion(), there's much less chance of function clashes.
