  3. assert results
  • Views 16702
assert results
jshafer
jshafer over 16 years ago
How can I get the Spectre assert results using SKILL? I want to be able to set some asserts, run corners using the corners tool, and get back a list of violations at each corner. I can see SOME of the results using the results browser, but it doesn't tell me which device instance is in violation. The ADE window does using Results|Violations Display. So there must be some way to get this data. If I open the tranViolations.violations file in the PSF directory using a hex editor, I can see instance names in there. So the data is stored, but getting at it is the mystery here.
    You can use these commands to get info about the assertions themselves:
    selectResult('asserts)
    outputs() => names of all the asserts
    assInfo=getData("/peakFail") ; peakFail is the name of one of my asserts
    ocnPrint(assInfo)  ; shows the info associated with that assertion - for example:
     ocnPrint(a)
    signal            getData("/peakFail" ?resultsDir "simulation/ampTest/spectre/schematic/psf" ?result "asserts-info.assert")
    dev               I7.Q0
    duration          0
    expr
    info              no
    level             warning
    max               4.5
    message
    min               0
    mod
    modelparam
    name              peakFail
    param             vce
    primitive
    sub
    values
    I could then get individual parameters by doing:
    pv("/peakFail" "max") => "4.5"
    For the violations, you can use:
    selectResult("tranViolations-violations")
    outputs() => list of violation names (these are of the form assertion.instance.violationN).
    viol=getData("peakFail.I7.Q0.violation1")
    viol->??  ; lists all the property name/value pairs . e.g. startStep, endStep, duration
    pv("peakFail.I7.Q0.violation" "startStep") => 1.981172e-07
    ; or
    viol->startStep  ; gives the same thing
    If you want to find the instance name from the violation, you can use:
    drlGetProperty(viol "instance") => ("I7.Q0")
    The other properties you can get with drlGetProperty on a violation are "assert", "instance", "model", "expression", "severity", "status".
    Note that drlGetProperty is not documented or public - you should probably log a service request with Cadence Support to request that this (or an equivalent function) is made public.
  • jshafer
    Thanks, Andrew. I had figured everything out except the drlGetProperty() function. I'll ask them to make it public.
