  3. help needed to solve the bug in this small code?
  • Views 15032
Prabhu The ICL
Prabhu The ICL over 16 years ago
Hi, All! Can someone find out the bug in the following code.
I trying to print the points which are not on the specified grid 0.01 in my case.
When I run this code I am getting all the points including the one which are on grid also.
/*******************starts here************************/
outport = outfile("grid.txt")
fprintf(outport "OldCoordinate            NewCoordinate\n")
procedure(  CCSroundCoord(  point xgrid ygrid compFactor )
        prog(  ( x y )
             x=round( ( xCoord( point ) + compFactor ) / xgrid ) * xgrid
             y=round( ( yCoord( point ) + compFactor ) / ygrid ) * ygrid
         if(x!=xCoord(point) then  fprintf(outport "%L               %L\n" xCoord(point) x ))
         if(y!=yCoord(point) then  fprintf(outport "%L               %L\n" yCoord(point) y ))
             return( list(  x y  ) )
procedure(grid(val @optional (cv deGetEditCellView()))
  foreach(shape cv~>shapes
      case(shape~>objType
          (("rect" "dot")
              foreach(ord shape~>bBox CCSroundCoord(ord val val 0.001))
          (("polygon" "path" "line")
              foreach(ord shape~>path CCSroundCoord(ord val val 0.001))
          (t
              printf("Unknown Object Type %s\n" shape~>objType)
      );case
  );foreach
);grid
grid(0.01)
close(outport)
/*******************ends here************************/
Thanks in Advance...
Prabhakar. K -- The ICL Engineer
SoCtronics
  • dmay
    dmay over 16 years ago
    Prabhakar,
    The problem is your float comparison: x!=xCoord(point)
    This is running into a floating point limitation where there are differences in the numbers at some very insignificant digits. You'll see differences like this:    5.400000000001 !=  5.3999999999999
    Create a procedure for doing a "float equal" check:
    procedure(myFloatEqual(a b @optional (epsilon 0.000001))
        if(abs(a-b) < epsilon
            t
            nil
    ) ;proc
    Replace your comparison/print lines with these:
             if(!myFloatEqual(x xCoord(point)) then  fprintf(outport "%12.3f             %12.3f\n" xCoord(point) x ))
             if(!myFloatEqual(y yCoord(point)) then  fprintf(outport "%12.3f             %12.3f\n" yCoord(point) y ))
    You should then get your expected results.
    Derek
  • Prabhu The ICL
    Hi, Derek!
    Yes, I am getting my expected results now. It's
    really a good idea.
    Thank you very much....
    Regards...
    Prabhakar. K The ICL Engineer
    SoCtronics
