  3. Skill code for calculating length of a path with bends
  • Replies 7
  • Subscribers 150
  • Views 20555
Zebib
Zebib over 16 years ago
 I am trying to calculate the length of a given path with many bends using a skill code.
  • skillUser
    skillUser over 16 years ago
     Hi Zebib,
    There is an existing Solution 11422112 that may help with what you are asking.
    Alternatively, here is another (more simplistic) SKILL example that I wrote:
    * DISCLAIMER: The following code is provided for Cadence customers *
    * to use at their own risk. The code may require modification to *
    * satisfy the requirements of any user. The code and any *
    * modifications to the code may not be compatible with current or *
    * future versions of Cadence products. *
    * THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING *
    * WITHOUT LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES *
    * OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. *
    * CCSgetPathLength() *
    * Uses the selected object, if no object is selected then the *
    * current mouse pointer location is used (if infix is on). If *
    * the object is a path then iterate over the points and sum *
    * the length of each segment (works for 45 degree segments). *
    * Prints the summed length of the selected path in the CIW. *
    procedure(CCSgetPathLength(@optional (obj car(geGetSelectedSet())) silent )
    let((prevpt x y (length 0.0))
    ;; if no object is selected, and infix is turned on, then
    ;; use the current mouse location to select the object.
    ;; This is for use with a bindkey, i.e. it is set to run
    ;; this procedure when a key is pressed.
    unless(obj
    when(hiGetCIWindow()->infix
    geSelectPoint(nil enterPoint())
    obj = car(geGetSelectedSet())
    ;; when the selected object is a path object, iterate
    ;; over the list of points and sum the length. This
    ;; assumes orthogonal or 45 degree segments only.
    when(obj~>objType == "path"
    foreach(pt obj~>points
    ;; operate on pairs of points, if no previous point
    ;; then set it to be the same as the first and use
    ;; it in the next iteration.
    if(!prevpt then
    ;; initialise prevpt to be the first point
    prevpt=pt
    else
    ;; for simplicity keep the calculation the same
    ;; regardless of which direction the segment is
    ;; oriented. One of x or y will be 0 unless the
    ;; path segment is not horizontal or vertical.
    x=abs(car(pt) - car(prevpt))
    y=abs(cadr(pt)-cadr(prevpt))
    length = length + sqrt(expt(x 2) + expt(y 2))
    prevpt=pt
    );; foreach
    ;; print the summed length to the CIW, length will
    ;; have a value as it was initialised as 0.0
    unless(silent
    printf("Path length: %5.2f\n" length)
    ;; return the length calculated
    length
    );; when selected object is a path
    );; let
    );; procedure CCSgetPathLength
    The above code only calculates the length of a path object type (i.e. OA 'pathSegs' are not considered) and does not consider any layer change or overlaps (or non flush end-types) , but hopefully it is helpfulto you.
    Lawrence.
  • Zebib
    skilluser,
    Thanks. It works!
    Zebib
  • Zebib
    Hi skilluser,
    Your skill code for finding the length of a path works fine. I also tride to do similar code for rectangles which
    is ofcourse much simpler than that od the path. Now I am wondering if you have a skill code that would calculate the length of a polyon of several bends and different width.
    By the way I am trying to learn skill code and where can I find skill codes so that I can learn from them.
    Zebib
    What does the "length" of a rectangle mean? Unless you know the direction, you don't know which is the "length" and which is the "width".
    With a rectangle object you have the ~>bBox attribute - from that it's easy to compute the length of each side.
    For a polygon, I've no idea what "length" means.
    In order to learn more about SKILL:
    1. Read the SKILL User Guide in the documentation
    2. Look at examples on Cadence Online Support (support.cadence.com) - particularly in the Resources section at the top
    3. Look on this forum
    4. Look on the comp.cad.cadence usenet news group (look on google groups)
    5. Attend a SKILL Language Programming class (follow the Education link at the top of the page)
    6. Experiment (in conjunction with the documentation)
    7. Experiment some more...
  • Zebib
    Andrew,
    If you have an L-shaped path and then if this path is converted to a polygon, how do you calculate its length.
    I will do some more reading as you suggested. I wish I could get more skill programs that I can learn from.
    Zebib
    Zebib,
    There are lots of examples around, in the places I mentioned.
    One approach you could use is to use code like this to convert a polygon back into a path. A bit of a brute-force (not the most elegant thing I've ever written), but it's one approach. It assumes it is really like a path - i.e. constant "width". Also deals with rectangles (see comments in code).
    Having converted to a path, you could calculate the length as Lawrence suggested before.
  • twen
    twen over 11 years ago
    Is there any way that I can use the length measurement skill code to dynamically display the total path length while I stretch a path segment like the tool bar's X,Y,dX,DY? This feature will be useful when I try to create hundreds of length-matched irregular paths. Stretching a path segment, selecting it again, and then pressing a key to display it is not convenient in this case. Thanks, TJ.
