  3. problem with dbFindProp()....?
  • Views 16163
Prabhu The ICL
Prabhu The ICL over 16 years ago
Hi, All! I am using Cadence IC514 version.
I found a code which increases the parameters by a given factor in schematic.(i.e width and length etc...)
My problem is as follows...
I have two instances pch_25_mac with
              1)    "w"="5u" and "l"="500n" and                 2)    "w"="5u" and "l"="280n"(this is the default value for this parameter)
dbFindProp(inst prop) is returning it's id on first instance but it is not when the parameter value is default value.
How to resolve this problem...
Here is the code that I have got....
procedure(CCS_ModifyWL(lib cell factor "ttn")
let((cv new propId)
 cv = dbOpenCellViewByType( lib cell "schematic" "" "a")
 when( cv
   foreach(inst cv~>instances
     ;foreach(prop list("w" "l")
     cdf1=cdfGetInstCDF(inst)
     foreach(prop list("w" "wf" "l" "wr" "lr" "sumW" "sumL")
     if(member(prop cdf1~>parameters~>name) then
       ;when(propId=dbFindProp(inst prop)
   propId = cdf1~>prop
         new = sprintf(nil "%g" cdfParseFloatString(propId~>
value)*factor)
         printf("Changing instance %s property %s from %s to %s.\n"
           inst~>name propId~>name propId~>value new)
         dbReplaceProp(inst propId~>name "string" new)
       );when the prop exists
     );foreach prop
   );foreach inst
   ;dbCheck(cv)
   ;dbSave(cv)
   ;dbClose(cv)
 ); when the cellview was opened ok
);let
);procedure
Thanks in Advance
Prabhakar. K --- The Layout Engineer
SoCtronics
    This is correct behaviour. dbFindProp only deals with db property objects. When CDF is being used, the default values are not (normally) stored on the instance, and so there is no property object to find.
    One way to handle this is to use cdfGetInstCDF (as you have) and then replace the line:
       propId = cdf1~>prop
    with
       propId = get(cdf1 prop)
    I didn't test the code, but I think it should all work with that change
  • Prabhu The ICL
        I am very very Sorry, for the mistake made to the previous message ... This is the actual code which I have got...
        let((cv new propId)
         when( cv
               new = sprintf(nil "%g" cdfParseFloatString(propId~>value)*factor)
                 printf("Changing instance %s property %s from %s to %s.\n"  inst~>name propId~>name propId~>value new)
             );foreach prop
           );foreach inst
           ;dbCheck(cv)
           ;dbSave(cv)
           ;dbClose(cv)
        );let
        );procedure
        Thanks in Advance
        SoCtronics
  • Prabhu The ICL
    Hi, Andrew,
                       With your suggestion I have modified the code as follows....
    procedure(SoC_ModifyWL(libName cellName factor "ttn")
        let( (cv cdfId new)
        cv = dbOpenCellViewByType( libName cellName "schematic" "" "a")
        when(cv
            cdfId = cdfGetInstCDF(inst)
            foreach(paramId cdfId~>parameters
                    if(member(paramId~>name list("w" "wf" "l" "wr" "lr" "sumW" "sumL")) then
                        new = sprintf(nil "%g" cdfParseFloatString(paramId~>value)*factor)
                        printf("Changing instance %s property %s from %s to %s.\n" inst~>name paramId~>name paramId~>value new)
                        paramId~>value = new
                    );if
            );foreach
        );foreach
        );when
            dbCheck(cv)
            dbSave(cv)
            dbClose(cv)
        );let
    );SoC_ModifyWL
    cell_list = nil
    procedure(SoC_Traverse(@optional (cv geGetEditCellView()))
        printf("changing properties of -- %s -- cell\n" cv~>cellName)
        SoC_ModifyWL(cv~>libName cv~>cellName 1.1)
            if(!member(inst~>cellName cell_list) then
                cell_list = cons(inst~>cellName cell_list)
            if(inst~>libName == cv~>libName && ddGetObj(inst~>libName inst~>cellName "schematic") then
                println(inst~>name)
                master = dbOpenCellViewByType(inst~>libName inst~>cellName "schematic" nil "a")
                SoC_Traverse(master)
            );if
            );if
        );foreach
    );SoC_Traverse
    As I observed it's working fine ... Is this the good way...?
