  3. Need help in changing the pin text.
  • Subscribers 152
  • Views 15965
Raghu111
Raghu111 over 16 years ago
Hi Andrew Beckett,
 I have used many of your skill progammes and they are very good.
Do you have a program that can modify 'part of the' string in the selected pins and associated labels ?
Example :
i have,
datainput<1>
datainput<2>
datainput<3> .
There is a label and a corresponding pin with it.  Now i want to select all the pins and labels and convert them like
dataoutput<1>
dataoutput<2>
dataoutput<3>
 Effectively  'input' need to be changed to 'output'
Currently i have a skill which can change the label. Do you have a script which can change the label and the pin associated with it.
Thanks in advance
Raghu
    Hi Raghu,
    As if by magic, yes I do. It's in Cadence Online Support Solution 11347874
  • Raghu111
    Thank you so much. Script is wonderfull.
    Raghu
  • VaughnR
    VaughnR over 15 years ago
     Can someone update the link to this solution? I need to see this code.
  • VaughnR
     Sorry if this is a duplicate reply. I would like to see this pin code. Please update the link.
    There's nothing wrong with the link, so it doesn't need updating! You do however need an account on Cadence Online Support to view it - so you'd need to register.
