  3. help: script to merge path in layout
  • Views 15456
lrl12skdev
lrl12skdev over 16 years ago
 Hi Everyone,
 does anyone have a script to merge selected path even if their wireends are not on the same point or along a straight line?
would be much better if it can also join paths of different layer and/or different width. That is, the resultant path will base its parameters from the first selected object. I am trying to look now in the cadence center but I don't think I could find exactly what I want.
 many thanks in advance.
 regards,
rence
  • lrl12skdev
    Hi All,
     I have manage to do it now.  luckily I found in the doc regarding the function geCompressPointArray and it makes my algorythm simple.
    BR,  rence
