  3. Help with custom skill code for substrate contact
  • Subscribers 152
  • Views 14853
zeroskills
zeroskills over 16 years ago
I would like some help with custom skill code for substrate contact.
The description is, when i hit my bindkey 8 - it will change a nwcont to subc, then when i hit 9 -  it will change a subc to nwcont, i would like to do just 1 binkey to toggle both of them, just hit bindkey 9 - it will change subc to nwcont, or nwcont to subc.
Thanks for the help.
  • lrl12skdev
    lrl12skdev over 16 years ago
     Hi Zeroskills,
     I think the best way to do it is to change the code a little bit in such a way it would work as describe below
    foreach selected instance check if it is subc or nwCont and then replace it with its opposite.
    once you do this you won't even need to have the argument "change_to_sub" and then you can just bind this funtion to key<9>,
    I hope this helps you.
    BR,  rence
