  3. Error using leSearchHierarchy()
  • Replies 8
  • Subscribers 152
  • Views 18413
LeJonT
LeJonT over 16 years ago
I am trying to use leSearchHierarchy() function to list all labels in a layout. Code below:
cellView = dbOpenCellViewByType( libName topCellName "layout" )
labelsInLayout = leSearchHierarchy( cellView cellView~>bBox 32 "label" list( ) )
But, instead of all labels hierarchically, it is listing the labels in Top View only.
Strange thing is, if I open the Top Layout using the editor and run the code again, it is listing all the lables in all levels. Same way, it is lisiting all the layers once the layout is closed too.
What can be the possible reason for this strange behaviour? Am I missing something? (I am using ic5.1.41)
-Thanks and Regards,
Leo
  • LeJonT
    This is the one solution that I found out..
    cellViewID = dbOpenHier( cellView 32 ) ;open/bind master of insts contained in the cellview
     Any other options?
    -Leo
    Leo,
    I replied by email earlier, but for some reason it did not appear - my suggestion was to use dbOpenHier, as you've found. If you've opened the design interactively, it may have opened the entire hierarchy (particularly if the stop level is set to maximum) - there's a cdsenv to control this. If you did it from SKILL using dbOpenCellViewByType(), it does not open the entire hierarchy unless you explicitly ask it to (with dbOpenHier) for efficiency reasons.
    So that is the best solution... You could also traverse the hierarchy itself, which would cause the masters to get elaborated as you request them, but since your search is so simple, using leSearchHierarchy does most of the work for you.
    Call dbOpenHier(cellView 32) first to ensure the hierarchy is opened. When you're opening in the layout editor, it's probably opening it to full depth.
  • Meelow
    Meelow over 15 years ago
    Hi Leo (and Andrew)
    Where do I get Information about the function leSearchHierarchy() ? I can't find it in my "Virtuoso Design Environment SKILL Reference"
    I am using Virtuoso 6.1.x, might this be a problem?
    Thanks a lot
    Milo
    Hi Milo,
    Why not run "cdnshelp" and search for it?
    It will be in the layout editor SKILL functions manual (at a wild guess without checking).
  • LeJonT
    LeJonT over 15 years ago
    Hi Milo,
    As Andrew mentioned, you should be able to find it in cdnshelp. You will find it in "Layout SKILL Functions Reference" (sklayoutref.pdf) as well.
    Leo
  • Meelow
    Hey,
    thanks for all the hints. cdnshelp seems to be broken in my installation. I will figure out that later :-)
    I found the documentation in the Layout SKILL Functions Reference as LeJonT pointed out.
    Another good solution to my problem is using the binary "cdsFinder" as I discovered some days ago.
    Happy Layouting ;-)
    Milo
    Maybe you're running one of the early IC61 releases (6.1.0 or 6.1.1) which were before cdnshelp was introduced? If so, it would be "cdsdoc" in those releases.
