  3. A question about ccpCopy()...?
  • Views 18210
Prabhu The ICL
Prabhu The ICL over 16 years ago
Hi! All, I am using Cadence IC514 version.
I have written the following script to copy a library to another library along with a new cell prefix added to all the cells.
/**********************soc_copy_add_prefix.il************
procedure(SoCrenameWithPrefix(libName topcell dlib prefix)
   let((src dst newName)
           srcList = gdmCreateSpecList()
           dstList = gdmCreateSpecList()
       foreach(cell ddGetObj(libName)~>cells
           if(cell~>name==topcell || rexMatchp("^rooTCA*" cell~>name) then
               newName = cell~>name
           else
               newName=strcat(prefix cell~>name)
           );if
           src=gdmCreateSpec(libName cell~>name nil nil "CDBA")
           gdmAddSpecToSpecList(src srcList)
           dst=gdmCreateSpec(dlib newName nil nil "CDBA")
           gdmAddSpecToSpecList(dst dstList)
       );foreach
           ccpCopy(srcList dstList t 'CCP_EXPAND_ALL nil nil "" "CDBA" 'CCP_UPDATE_DESTLIB_ONLY)
       println(" ccpCopy : Copy Job done ")
   ) ; let
) ; procedure
/**************************Ends here****************************************/
The code is working for all of my libraries except for a library....
The copying is taking place successfully while in the updating process it is giving the following warnings.
Info (ccp): ccpCdbaUpdtr ran successfully ...
\o (ccpiDispatchUpdators) Performing instance update.
\o
\w *WARNING* (ccpiDispatchUpdators) Error in running the updator: ccpHdbUpdtr for the data type: HierarchyDescription
\w
\w *WARNING* (ccpiDispatchUpdators) The updateFileList is at: /tmp/ccpHdbUpdtrOZnyQj
\w And the fullFromToListFile is at: /tmp/copyCcpP1of2rbCgAE
Can someone explain me what does this warning mean...?
Is there any probelm with the above code..? (However, it's working for other libs)
I tried using the namespace "LibraryUnix" instead of "CDBA" ...(giving same warning)
Is there any problem with the namespace...?
I hope the problem is understandable....
Thanks in Advance...
Prabhakar. K --- The ICL Engineer
SoCtronics
  • lrl12skdev
    lrl12skdev over 16 years ago
    You are copying a topcell with subcells, in which I can only assume that there is a possibility that a subcell is reference from two diferent libraries. for example you have 2 "buffer" instances in the topcell, one is reference to libA and the other is referenced to libB,
    since you are copying all views including files like prop.xx then you will have a problem if you have not enabled the env variable auto rename because it cannot copy same file coming from to different locations to a newLib.
    I hope this makes sense.
    best regards
