  3. database pointers as properties in Virtuoso L 6.1.3
  • Views 15085
MichaelKoch
MichaelKoch over 16 years ago
Hell,
I want to store a relationsship between two shapes within a cellView.
Comparable to the connectivity, which returns the dbPointer to the net
i.e.
x=css()
x~>net
What is the best way to do ?
My ideas were to store database pointers from object1 to object2 within a property, but I did not find a way to
do this, since properties of type dbPointer are not permitted.
The other way would be to store uniq Ids within properties, but this is slow, when searching for objects of the
same property.
    This is what groups are for. Look at dbCreateGroup() and you can retrieve the groups via cv~>groups. Note that groups are only available on cellViews.
