  3. unbound variable
  • Views 19801
unbound variable
vagaobr
vagaobr over 16 years ago
My name is Vagner, this is the first time I am accessing this forum.
I created a small sklill script to load  different "cdsinit" file, through of the environment variable "TEC_PROC", but when I start icfb tool, I have a error message:
*Error* eval: unbound variable - xc06
<<< Stack Trace >>>
(TEC_PROC == xc06) .
See below my skill script. Do you known where my script is wrong?
TEC_PROC = getShellEnvVar("TEC_PROC")
if(TEC_PROC==xc06 then
      printf( "Starting technology customization load.\n" )
load("/tools/site/ic/5141_ISR201003011550/tools/dfII/local/cdsinit_xfab/cdsinit_xc06")
     printf( "Done technology customization load.\n" )
      else
      if(TEC_PROC==xc06_m3 then
      load("/tools/site/ic/5141_ISR201003011550/tools/dfII/local/cdsinit_xfab/cdsinit_xc06_m3")
              else
              if(TEC_PROC==xc06m3pin then
              load("/tools/site/ic/5141_ISR201003011550/tools/dfII/local/cdsinit_xfab/cdsinit_xc06m3pin")
            else
            if(TEC_PROC==xc06ml then
            load("/tools/site/ic/5141_ISR201003011550/tools/dfII/local/cdsinit_xfab/cdsinit_xc06ml")
                else
                if(TEC_PROC==xc06pin then
                load("/tools/site/ic/5141_ISR201003011550/tools/dfII/local/cdsinit_xfab/cdsinit_xc06pin")
Vagner
  • dmay
    dmay over 16 years ago
    You are comparing TEC_PROC (a variable) to xc06 (a variable). You set TEC_PROC to be the result of getShellEnvVar("TEC_PROC"), but xc06 is unbound. You should put it in quotes so that you will be checking for a specific string value:
    if(TEC_PROC == "xc06"  then
      if(TEC_PROC == "xc06_m3" then
    Derek
  • vagaobr
    Hi Derek,
    Thank very much for your help. The problem is solved.
    Vagner
