  3. Question regarding running parametric simulations using...
  • Replies 15
  • Subscribers 153
  • Views 23302
Question regarding running parametric simulations using Ocean
gurusub
gurusub over 16 years ago
 Hi all,
I have a set of design variables in my schematic. I would like to input multiple data vectors to my schematic and save the output data in Ocean
For example, If P is a set of parameters P={p1,p2,p3,p4} (p1-p4 are the design variables in the schematic). I would create a matrix of data values with different instances of P ie my data matrix would look like
Q=[-------P1---------
     --------P2---------
    ---------P3--------]
and so on where each Pi contain (p1i, p2i,p3i,p4i). (In other words I want to use the analogus of paramset command in Spectre for ocean). I would like to simulate my circuit for these values in Q and make some measurements using Calculator function and finally store the output data in the text file. Can somebody please go through the steps in accomplishing the same?
Guru
    Hi Guru,
    You can do this with OCEAN quite easily, as the paramAnalysis function supports paramset:
    paramAnalysis("CAP" ?values '(6e-13 8e-13 1.2e-12 1.5e-12 ) ?sweepType 'paramset
      paramAnalysis("temp" ?values '(20 40 60 80 ) ?sweepType 'paramset
    paramRun()
    You need to define a set of nested paramAnalysis calls, with a list of values, with sweepType set to 'paramset as shown. The list has to be the same length for each paramAnalysis, but then it will do (in the above case) 4 runs.
    Then when you access the results after the simulation, you will get waveforms which are a 4-member family - you can then do your calculations as normal in the calculator, and anything that you calculate which would result in a scalar for a single run, will end up as points versus the swept variables. For example, if I do ocnPrint(ymax(v("/out" ?result 'tran))) you get this:
    # Set No. 1
    (CAP = 600f)
    temp              ymax((v "/out" ?resultsDir "/users/ME/simulation/ampTest/spectre/schematic" ?result "tran"))
    20                  149.795m
    # Set No. 2
    (CAP = 800f)
    40                  146.225m
    # Set No. 3
    (CAP = 1.2p)
    60                  140.35m
    # Set No. 4
    (CAP = 1.5p)
    80                  133.77m
  • gurusub
     Thanks Andrew. It worked. I would like to read my vectors in Q from an input file. Something like one file for each element in Q. How do I read files using Ocean.
    Guru
    Hi Guru,
    Imagine you had a file "paramdata" containing the following:
    20      40      60      80
    1.2     1.1     1.3     1.1
    Then in your OCEAN script you could do:
    dataPort=infile("paramdata")
    data=nil
    while(row=lineread(dataPort)
      ; use tconc to efficiently build the list in the same order as the file
      when(row!=t data=tconc(data row))
    ; because it was a tconc, need to use car to convert to a normal list
    data=car(data)
    Then you can do:
    paramAnalysis("CAP" ?values car(data) ?sweepType 'paramset
      paramAnalysis("temp" ?values cadr(data) ?sweepType 'paramset
          paramAnalysis("VDD" ?values caddr(data) ?sweepType 'paramset
    paramRun()
    Rather than using car, cadr, etc you could always use nthelem(1 data), nthelem(2 data) etc to pick off "rows" in the list. Essentially the variable data would contain a list of lists, with each sub-list representing a row in the data file.
    Hope that helps,
  • gurusub
     Thanks Andrew. You are simply awesome!!. Thanks for all the help.
  • gurusub
    I have one quick question. When I use the ocnPrint it prints out unwanted text into the file which I don't need. I would prefer using fprintf instead of OcnPrint. Suppose I am running a parametric sim on SP parameters and I would like to record all the S11 values and its corresponding frequency values into a text file how would I do that? The problem here is that I am not aware of the data structure of the S11. Is it stored as a list?. Is there a easy way of converting a list into an array?. I am very comfortable operating on array than on lists.
    Guru
  • TjaartOpperman
    TjaartOpperman over 16 years ago
    I tried this out in IC6.10 and it works very well. Btw the IC6.10 oceanref documentation has no reference to the ?sweepType parameter (or perhaps I missed it?) Scenario: ======= I'm now using this command to build nested sweeps. For example: I have a circuit with range of switches that has to toggle over the entire set, and then I sweep this for different capacitances, over some temperature range. In any case, this command works quite well for my scenario. Problem: ======= The only problem I'm having is that, since that selectResuts('tran) v("node") returns family of waves, I cannot seem to plot the waveforms using awvPlotWaveform(..). It seems that one has to revert to using the ocean plot(..) function. Personally I don't really prefer using the plot(..) function. I also need the re-group the family of waves back into the respective nested sweep sets. Question: ======= Is there a way the extract a waveform from the family of waves and then use awvPlotWaveform(..) ?
    I filed CCR number  799087 to get the documentation fixed.
    I just did an awvPlotWaveform(winId list(v("node"))) and it worked fine with family data. If that doesn't work, perhaps you should contact customer support, providing your psf directory so that we can investigate. If you really want to pull it apart, you can do:
    sig=v("node")
    slice1=value(sig 'CAP 1.5p)
    slice2=value(slice1 'VDD 2)
    etc. You can either use the value() function without a parameter name, and then it finds the value against the innermost sweep (which might be time, frequency if it's a tran or ac analysis, or you can give one of the sweepNames.
  • gurusub
    Can you please take time to answer my question as well?.
    Guru
    Hi Guru,
    Apologies - I overlooked your earlier post. I've been travelling in Israel this week and so have only a little time to keep up with the forums.
    This could should give you some pointers. You might need to do a little work to cope with the fact that the s-parameter results will be complex numbers at each frequency point, so you might need to change it to print the real() and imag() or mag() and phase() at each frequency point, but I think it should give you the general principles:
    /* abDumpWaveform.il
    Author A.D.Beckett
    Group Custom IC, Cadence Design Systems Ltd.
    Machine SUN
    Date Oct 23, 1997
    Modified Jan 31, 2005
    By A.D.Beckett
    Functions for dumping a waveform to a file (few esoteric functions removed from this file when posted
    on Cadence Community Forums in order to stop it getting too long)
    Examples:
    abDumpWaveform(VT("/c") "data_c.out")
    abDumpWaveform(VT("/c") "data_c.out" "%e %e\n") ;; exponential format
    abDumpWaveformSplit() is equivalent to abDumpWaveform, but splits
    into files a little less than 2Gbytes (the split limit is an optional
    argument).
    ;; multi-variable output
    ;; all waveforms must share same x-axis, as it doesn't do any interpolation (for
    ;; speed reasons). Interpolation could be done by collecting all the x-values, and
    ;; then using the value function.
    abDumpWaveforms("data.out" VT("/c") VT("/z") VT("/a"))
    abDumpWaveforms("data.out" VT("/c") VT("/z") VT("/a") ?format "%-10g" ?separator ",")
    ;; can also write out multiple files if presented with a family
    abDumpFamily(VT("/c") "data.out")
    SCCS Info: @(#) abDumpWaveform.il 11/20/08.15:26:13 1.6
    * (abDumpWaveform wave fileName @optional (format "%g %g\n")) *
    * Take a waveform object, write it out to the fileName specified *
    * with the format given. No sampling is done. *
    (procedure (abDumpWaveform wave fileName @optional (format "%g %g\n"))
    (let (port (xVec (drGetWaveformXVec wave))
    (yVec (drGetWaveformYVec wave)))
    (unless (setq port (outfile fileName))
    (error "Could not write to file %s\n" fileName))
    (for pos 0 (sub1 (drVectorLength xVec))
    (fprintf port format
    (drGetElem xVec pos)
    (drGetElem yVec pos))
    (close port)
    * (abDumpWaveformSplit wave fileName @optional *
    * (format "%g %g\n") (split 2**31-512) ) *
    * with the format given. No sampling is done. Splits into *
    * multiple files when the number of bytes exceeds split *
    (procedure (abDumpWaveformSplit wave fileName @optional (format "%g %g\n") (split 2**31-512))
    str (len 0) (suffix 0))
    (sprintf str format
    (setq len (plus (strlen str) len))
    (when (greaterp len split)
    (close port)
    (postincrement suffix)
    (setq len (strlen str))
    (unless (setq port (outfile (sprintf nil "%s_%d" fileName suffix)))
    (error "Could not write to file %s_%d\n" fileName suffix))
    (fprintf port "%s" str)
    (close port)
    * (abDumpFamily family fileNamePrefix @optional (format "%g %g\n")) *
    * Write out a sequence of files for a family. Could potentially do *
    * this automatically inside abDumpWaveform, but it's hard without *
    * using private functions. *
    (procedure (abDumpFamily family fileNamePrefix @optional (format "%g %g\n"))
    (let ((xVec (drGetWaveformXVec family))
    (yVec (drGetWaveformYVec family))
    index
    (if (drIsWaveform family)
    ; then
    (abDumpWaveform family fileNamePrefix format)
    ;else
    (setq index (drGetElem xVec pos))
    (unless (stringp index)
    (sprintf index "%L" index))
    (rexCompile "[^a-zA-Z0-9.]")
    (setq index (rexReplace index "_" 0))
    (abDumpWaveform
    (sprintf nil "%s_%s" fileNamePrefix index)
    format
    ) ; if
    * (abDumpWaveforms fileName @key (format "%g") (separator " ") @rest waves) *
    * Write out a group of waveforms with a common x-axis to a file. It checks *
    * to see if the x-axis is the same, because otherwise some kind of interpolation *
    * would be necessary. An optional format string can be specified, so that *
    * the precision can be controlled. Also, an optional separator may be given. *
    (procedure (abDumpWaveforms fileName @key (format "%g") (separator " ") @rest waves)
    (let (port xVec)
    (setq xVec (drGetWaveformXVec (car waves)))
    ; check to see if all waveforms have same X-axis
    (when (exists wave waves (neq xVec (drGetWaveformXVec wave)))
    (error "All waveforms must have same x-axis")
    (foreach wave waves
    (fprintf port "%s" separator)
    (fprintf port format (drGetElem (drGetWaveformYVec wave) pos))
    (fprintf port "\n")
    (close port)
    * (abDumpSampledWaveform wave samplePoints fileName @optional (format "%g %g\n")) *
    * Dump the waveform at the sampled points passed in. wave is a waveform *
    * object, samplePoints is a list of x points to sample at, *
    * fileName is the file to write to, and format is an optional formatting string. *
    (procedure (abDumpSampledWaveform wave samplePoints fileName @optional (format "%g %g\n"))
    (let (port)
    (foreach point samplePoints
    point
    (value wave point))
    (close port)
  • KMan2011
    KMan2011 over 15 years ago
    Hello Andrew,
    Is there an instance when using the paramAnalysis and paramRun() functions that you may not output the indivdual 'case' data during a process simultion?  Interestingly, I output caluclated values for a t_delay parameter and also case for 2 signals which are independent of these parameters, but just not for the net which is dependent.  As if it doesn't know where to look.
     On the theme of Parametric sims, can I ask how one prints the simulation verbose to a separate text window than the CIW?  When I say run a parametric sim using the Cadence GUI, 2 text windows automatically popup with one showing the transient/AC/...blah run data (I think this is spectre.out file), and the other captures the iterations/nesting parameters.  Yet when I write a Skill code using the paramAnalysis and  paramRun() functions, the spectre.out run data is printed in the CIW.
