  3. Unknown error in Cadence
  • Subscribers 152
  • Views 16249
gurusub
gurusub over 16 years ago
 Hi all,
When I try to run paramteric simulations for my circuit, the simulator starts running and gets stuck. It returns with the following error
No method supplied for generic function asiGetStimulusDataStruct
How do I get rid of this problem?
  • Quek
    Quek over 16 years ago
    Hi gurusub
    May I have the following output?
    terminal>icfb -W
    An old bug with the same error message was fixed back in IC5.0. If you are not using the latest version of Virtuoso, the problem might go away if you update to the latest version.
    Best regards
    Quek
  • gurusub
    This is the output of icfb -W at the terminal
    sub version: 5.10.41_USR6.127.29
    Guru
  • Quek
    Hi Guru
    Thanks for the info. It looks like you are already using a fairly recent version of IC5141. I think it would be better for you to file a service request to the local Cadence support to troubleshoot this if it is reproducible.
    Best regards
    Quek
