  3. How to write skill to change library access permissions
  • Views 18607
archive over 16 years ago
Hi All,
I am trying to write a skill code to change the access permissions of a specific library. e.g I want to change the library "Test" to read only for all and then I want to change the access back to read/write for all.
Vijay
  • Quek
    Quek over 16 years ago
    Hi Vijay
    I cannot find any public design management SKILL API to do this so I guess you would have to use something similar to the following:
    procedure( CCSchangeLibMode(myLib mode)
       let( (libId)
          libId=ddGetObj(myLib)
          sprintf(cmd "chmod %n %s" mode myLib~>readPath)
          system(cmd)
          printf("Changed permission of lib %s to %n\n" myLib mode)
       ) ;let
    ) ;procedure
    === Owner read/write/execute ===
    CCSchangeLibMode("test" 755)
    === Owner read/execute ===
    CCSchangeLibMode("test" 555)
    Best regards
    Quek
    Hi Quek,
    Thank you for your quick response. I was thinking of writing a shell script for that purpose, but I was thinking about it and came up with a better idea:
    My idea is to specify a cellname and change the permissions of all cellview under the cell name hierarchically. I am new to SKILL, I am not sure how to get the list of cells in the hierarchy if I provide the parent cell name.
    Could you please point me in the right direction?
    Vijay
  • Quek
    Hi Vijay
    You can use the following script. Save it as "getcells.il" in the working directory and load it in ciw using:
    load "getcells.il"
    Open your top level layout and enter the following in ciw:
    CCSallCells()
    The names of all subcells will be returned as a list.
    Best regards
    Quek
    procedure( CCSgetCells(cv cellList)
       foreach( master cv~>instances~>master
          let( (nextCv)
             nextCv=master
             cond(
                (!nextCv nil)
                (member(nextCv cellList) nil)
                (t cellList=CCSgetCells(nextCv cons(nextCv cellList)))
             ) ;cond
          ) ;let
       ) ;foreach
       cellList
    ) ;procedure
    procedure( CCSallCells()
       let( (cellList)
          cellList=CCSgetCells(geGetWindowCellView() list())
          cellList~>cellName
       ) ;let
    ) ;procedure
    getcells.il
  • Quek
    Hi Vijay
    If you want to use the script by providing a top cell name, you can use this:
    procedure( CCSallCells(myLib myCell myView)
       let( (cellList cv)
          cv=dbOpenCellViewByType(myLib myCell myView)
          cellList=CCSgetCells(cv list())
          cellList~>cellName
       ) ;let
    ) ;procedure
    Sample cmd:
    CCSallCells("abcLib" "myTopCell" "layout")
    Best regards
    Quek
    Hi Quek,
    It works great. Thanks a lot!!
    Vijay
    Hi Quek,
    I am new to SKILL, I am not sure how to get the list of cells in the hierarchy if I provide the parent cell name. Could you please point me in the right direction?
    Vijay
