  3. How to instantiate a Qcell with given parameters..
  • Views 15405
avinash1skill
avinash1skill over 16 years ago
When i try to instantiate Qcell (cdsmos) in a cellview through skill it gives evaluation failure message. I have a few questions... I would like to know how to pass on parameters like w & l ? Should Qcell be treated as Pcells ? Which fuction 2 be used to instantiate Qcell, dbCreateParamInst() function or dbCreateInst()? Thanks in advance..
    Yes, you should use dbCreateParamInst() or dbCreateParamInstByMasterName() :
     inst=dbCreateParamInstByMasterName(geGetEditCellView() "LIB1" "mynmos" "layout" "" 0:0 "R0" 1 list(list("fw" 'string "20u") list("l" 'string "2u")))
    but then you need to call the CDF callbacks:
    CCSinvokeInstCdfCallbacks(inst)
    using the code from https://support.cadence.com/apex/homePage
    Otherwise you'll have to also add the fingerWidth and fingerLength parameters (as floats) and also formalVersion (an integer, with value 3 in the case I tried - but best to use the callback).
  • avinash1skill
    Thanks Andrew its working ..
