  3. How to generate completed nets text file.
  • Subscribers 152
  • Views 15671
lrl12skdev
lrl12skdev over 16 years ago
Hi everyone,
 I would like to generate a text file listing all the incomplete/complete nets because I need to pass it on to another process. Is it possible to do these via Skill?. show incomplete nets return value is boolean but there is an output window listing the nets so there must be a way I just don't know how at the moment, Any Idea?
best regards,  lrlsk
  • Quek
    Quek over 16 years ago
    Hi Irlsk
    There does not seem to exists a single SKILL function to get incomplete/complete nets so I made use of the IC5141 showIncompleteNets form as shown below. Hope that it will be useful for you.
    Best regards
    Quek
    ; Tested using IC5141.500.6.142
    procedure( CCSgetNets()
       let( (icNetsForm icNets cNets icPort cPort correctForm)
          lxHiShowIncNets()
          icNetsForm=hiGetCurrentForm()
          if( symbolToString(icNetsForm->hiFormSym)=="_lxvIncNetForm" then
             icNets=icNetsForm->lxIncNetIncompleteListBoxField->choices
             cNets=icNetsForm->lxIncNetCompleteListBoxField->choices
             correctForm=t
          ) ;if
          hiFormCancel(icNetsForm)
          if( correctForm then
             icPort=outfile("./incomplete.nets")
             cPort=outfile("./completed.nets")
             foreach(net icNets
                fprintf(icPort "%s\n" net)
             ) ;foreach
             foreach(net cNets
                fprintf(cPort "%s\n" net)
             ) ;foreach
             close(icPort)
             close(cPort)
             printf("Incomplete nets: %L\n" icNets)
             printf("Completed nets: %L\n" cNets)
          ) ;if
       ) ;let
    ) ;procedure
    hiSetBindKey("Layout" "F10" "CCSgetNets()")
    getnets.il
  • lrl12skdev
    Hi Quek.
    Thank you very much. Your script works perfect and this is exactly what I have in mind. Thanks also for  the attachment, this saves me some time instead of copying and pasting the text because sometimes strange char appear by doing so.
     best regards,
    lrlsk
  • Quek
    Hi IrIsk
    It is good to know that the script is useful for you. : )  Next time when you encounter the strange char problem, try running the file through "dos2unix" cmd.
    linux>dos2unix myfile
    Best regards
    Quek
