  3. Detecting DFII bit mode?
  • Views 16200
berndf
berndf over 16 years ago
 is there a way to detect the bit mode DFII is running
Sub version:        sub-version  IC6.1.4.500.1  (32-bit addresses) <- ???
either before invoking virtuoso with a command line option or
with SKILL?
 Bernd
  • skillUser
    skillUser over 16 years ago
    Hi Bernd,
    I wrote CCSis64bit.il for this purpose, you should be able to get it from the solution 11153048.
    It should work okay I believe, let me know if there are any problems with it.
    Lawrence.
    Hi Bernd,
    You can also use system.LP64 to tell if it's 64 bit. system.? will tell you the available properties.
    system.ILP32 is true for 32 bit machines.
  • berndf
    Hi Lawrence,
     Thanks for the prompt reply, but
    getVersion(t) does not return a string containing any bit mode
    infromation, at least not in my version.
    getVersion(t)
    "sub-version IC6.1.4.500.1 "
    Bernd
    PS: Is there a way to change to plain text mode for editing in thi forum?
  • skillUser
    Hi Bernd,
    I get the following when I invoke 'virtuoso' in 64-bit mode and then run getVersion(t) in it:
    sub-version  IC6.1.4-64b.500.4
    So, if you do not see the "-64b" part of the string, then the executable is running in 32-bit mode, or at least that's my assumption.
    However, I was not aware of the system.LP64 or system.ILP32 properties (these do not appear to be documented?, but cool information Andrew, thanks!) - this appears to be more definitive.
    Lawrence.
    Lawrence,
    There's a recent CCR to get these properties documented, so hopefully they will be in the future.
