  3. CDF and PCells
  • Views 19089
CDF and PCells
DarioETH
DarioETH over 16 years ago
I would like to create a schematic PCell of a capacitor wich realizes the parallel connection of N unit capacitors I previously designed in a different library. The number N has to be defined only in simulation time (trough an ocean script or by ADE through Variables->Edit )
Up to now I managed to get the main PCell Skill code but I am having toubles in passing the variable N. I paste here the code:
/* dcUnitCapPCell_v2.il
Author D.A. Carnelli
Group Analog And Mixed Signal, ETH Zurich.
Machine SUN
Date Jul 1, 2010
Modified
By
SKILL code for creating the "UnitCap" pcell schematic
and the CDF as well
SCCS Info: %Z% %M% %G%.%U% %I%
let( (library cell pcellId)
library="DC_BBFlt"
cell="FiltCap"
unless(ddGetObj(library)
error("Couldn't open library %L" library)
; First the schematic
pcellId=pcDefinePCell(
                        list(
                             ddGetObj(library)
                             cell
                             "schematic_UnitCap_v2"
                             "schematic"
; Formal parameters
(multiplier 1)
; Code itself
let(( cv )
cv = pcCellView
; open master cell views
unitCapMaster = dbOpenCellViewByType( "dc_MMBBF_Aug09" "Cunit" "symbol" nil "r" )
; create the nets
netPos=dbMakeNet(cv "pos")
netNeg=dbMakeNet(cv "neg")
netGnd=dbMakeNet(cv "gnd!")    ;How to make this net inherited?
; create the terminals
dbCreateTerm(netPos netPos~>name "inputOutput")
dbCreateTerm(netNeg netNeg~>name "inputOutput")
; create the instances of mimCaps
unitCapID=nil
for( i 0 multiplier-1
unitCapID = cons(
                    dbCreateInst(
                                     cv
                                      unitCapMaster
                                      sprintf( nil "I%d" i)
                                    0:i
                                    "R0"
                                    multiplier-1
                    );dbCreateParamInst
                    unitCapID
);for
; Connect it up
dbCreateConnByName(netPos nth(multiplier-1-i unitCapID) "sw")
dbCreateConnByName(netNeg nth(multiplier-1-i unitCapID) "bot")
dbCreateConnByName(netGnd nth(multiplier-1-i unitCapID) "c0")
dbCreateConnByName(netGnd nth(multiplier-1-i unitCapID) "c1")
dbCreateConnByName(netGnd nth(multiplier-1-i unitCapID) "c2")
dbCreateConnByName(netGnd nth(multiplier-1-i unitCapID) "c3")
dbCreateConnByName(netGnd nth(multiplier-1-i unitCapID) "c4")
);for
; Make the connectivity look up to date - not always needed, but
; Assura needs this, for example.
dbDisablePropTimeStamp()
dbReplaceProp(cv "lastSchematicExtraction" "time" getCurrentTime())
dbClose( unitCapMaster )
t
) ; let
dbSave(pcellId)
dbClose(pcellId)
; Now create the CDF
let( (cellId cdfId )
unless( cellId = ddGetObj( library cell )
error( "Could not get cell %s." cell )
when( cdfId = cdfGetBaseCellCDF( cellId )
cdfDeleteCDF( cdfId )
cdfId = cdfCreateBaseCellCDF( cellId )
;;; Parameters
 cdfCreateParam( cdfId
     ?name "multiplier"
     ?prompt "Multiplier"
     ?defValue 1
     ?type "int"
;;; Simulator Information
cdfId->simInfo = list( nil )
cdfId->simInfo->UltraSim = '( nil )
cdfId->simInfo->ams = '( nil )
cdfId->simInfo->auCdl = '( nil )
cdfId->simInfo->auLvs = '( nil )
cdfId->simInfo->cdsSpice = '( nil )
cdfId->simInfo->hspiceD = '( nil )
cdfId->simInfo->hspiceS = '( nil )
cdfId->simInfo->spectre = '( nil )
cdfId->simInfo->spectreS = '( nil )
;;; Properties
cdfId->formInitProc = ""
cdfId->doneProc = ""
cdfId->buttonFieldWidth = 340
cdfId->fieldHeight = 35
cdfId->fieldWidth = 350
cdfId->promptWidth = 175
cdfId->paramLabelSet = "buswidth busvalue"
cdfId->paramDisplayMode = "parameter"
cdfSaveCDF( cdfId )
) ; let
) ; let
/*********************** END OF CODE *********************/
This works when I instantiate the PCell and I pass directly the number
I also tought to replace the CDF definition with this, it should be the correct vay to do that:
  ;;; Parameters
     ?name "multiplier"
     ?defValue "string"
     ?type "1"
     ?parseAsNumber "yes"
     ?parseAsCEL "yes"
It doesn't give errors in compilation but it doesn't work either. The default value is taken and the paramerer i pass is ignored.
Please I need help because my project got stuck!
Thank you.
Dario.
    Hi Dario,
    The comments your code look rather familiar ;-)
    Anyway, if you're going to make the CDF parameter a string, you would need to change your pcell code to something like this:
    ; Formal parameters
    (multiplier "1")
    and then inside the code do:
    multiplier=atoi(multiplier)
    or even
    multiplier=round(cdfParseFloatString(multiplier))
    Note this is a very quick answer - I didn't really check it...
  • DarioETH
    That's a modification of one of your examples :-), I already tried also the solution you mentioned but still doesn't work.
    In addition I tried to parse the input using these functions:
    env=aelEnvCreate('f)
    interpMult=aelEnvInterpret(env multiplier)
     multiplier=fix(cdfParseFloatString(interpMult))
    By doing that I can introduce in the CDF field of the instantiated PCell a formula which contains only numbers, but when I put a variable name i.e.: "submasterMult" (defined in the CIW),  it fails because the aelEnvInterpret() function does not recognize "submasterMult" as a global variable.
    Thank you for the quick reply you gave me.
    Dario.
